Full LED upgrade
The only thing I didn't get that I wanted was the full LED lights.
Does anyone know how complicated it is to change them, I know I won't get the intelligent functionality, this is just for looks.
Any help appreciated thanks
Here you go pal...tell them you want all the options and you want $40 less than what is on their website, they will do it. Ships same day. https://www.hidkitlights.com/
I found this product to be better than other kits I researched for several reasons. Here are some details. H7 Xenon HID conversion kit for both low beams and high beams. The bulb temp is 6000K- Diamond white, the slim ballast wattage is 55W (5000 lumens output, 20X brighter than stock) and they both come with warning cancellers. They are plug and play and do not require splicing or cutting. Mounting brackets and all wires included. Guaranteed no flickering, waterproof and shockproof.
Lifetime warranty.
Lifetime warranty.
Want to replace headlights above it has these
Whatever brand you go with, look to see if they offer a lifetime warranty, if the slim ballast if 35W or 55W, ensure you get the correct color temp bulb that you like, try to find a plug and play option, definitely make sure they come with warning cancellers so you don't throw error codes, check to see if the price is for just low beams or just high beams or both, etc etc
Panoramic glass roof
Memory package
Reverse camera
Amg bodystyling
Full leather > 1/2 leather
Flat bottom steering wheel
Also got fold flat rear seats and collision prevention
so what does your headlights do? i mean those 2 lines that you have, what do they do?
now if they dont light up like you wanted it to. that link you posted looks promising. reason why not a lot of people are responding to your query is probably not a lot has done it or has to do it.
goodluck!
goodluck!
These are my headlights, about 90% of cars in UK have these, they are LED dipped beam and halogen high beam with drl and indicator along the bottom.
Full LED were $2000 option on new cars
Yep i see the difference now. Pardon my ignorance coz most facelfted 212 down here has the 2 drl lines on the headlight which i so admire. I would do it if i were you mate. Just ask the seller if you could if itll work with your car the way you want it. Again goodluck and hope you get good results!
Back to mission to find out how to fit the real lights :-(
