2011 e350 Bluetooth Audio Enabling?
Cheers
I bought it CPO in 2/2012, maybe the COMAND was updated?
Let me know if you have questions, but mine works perfectly for: audiobooks, iPod, Pandora, etc...
Need to update command to work. You can enable it in the Eng Menu, but it won't auto connect you have to manually pair it to stream music. But my friend actually got it to auto -connect on the the new IOS 9.2 update. Its worth the try... maybe yours is the same.
I have a 2010 e350 tried enabling bt audio in engineering menu. But there is still no option to connect phone to stream music. If I update command center it will work ?
After you have enabled bluetooth in ENg Menu, did you try connect bluetooth audio manually? and it did not work?
