Sponsored by: CARiD
Speakers Melting
Old Oct 23, 2019 | 02:07 PM
  #76
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Ok, this is becoming ridiculous, this is clearly not an isolated issue, and with multiple vehicles having this same issue, its quite clear there is defect. Im not sure how extensive this can be, but it feels like it could potentially lead to a fire. I just shared my thoughts with some news stations in Canada. Mercedes is only willing to cover 25% of the parts + labour still $1500 repair, and I don't even know if this will fix the issue. I reported the issue with Trans Canada in regards to a recall.
The part I don't understand is if there is also an amplifier issue, as the subwoofer itself could not make the sound on its own, its the amp that provides sound to the speaker. So MB Dealer's diagnosis doesn't make any sense.
I don't know what to replace. There are many parts at play. If I replace the subwoofer, then there's a chance of it still burning out as the amp could be the problem as well.
Anyone still stuck?
Old Oct 23, 2019 | 02:45 PM
  #77
Rakhchaw's Avatar
E40p
Anyone still stuck?
So..I got it fixed by the dealer.
They changed amplifier and a loudspeaker as it says in the bill.
MB USA paid 20 percent of 3000+bill....It hurts ...
Old Oct 23, 2019 | 03:02 PM
  #78
akingzkid's Avatar
Veteran: Navy
2014 E350 4Matic
Hello all,
Had the same issue around 2 months ago. Passenger side front door tweeter started crackling, popping and smoking while I was driving. I had to immediately pull over and remove it as I thought it would result in a fire. I ordered a used speaker on ebay and put it in. It did not fix the issue. That one began to pop and heat up as well. Contacted local MBZ dealership and they said that extended warranty nor CPO warranty would cover repair. Decided to contact the dealership where I purchased the car (2014 E350) a little over 2 years ago as a CPO (they are 1.5 hours from my home) to see if I could appeal to them. They agreed to fix it as a "good will". In the end, they ended up saying that the CPO warranty covered it. I don't really care how they shuffled their paperwork to get it done. I'm just glad they did the right thing!! It ended up being the amplifier that they replaced, along with the affected tweeter. I believe the amplifier is the issue and the tweeter was only replaced because it was affected. So far so good a few weeks later.
Old Oct 23, 2019 | 03:10 PM
  #79
Originally Posted by akingzkid
Hello all,
Interesting, I was planning to spend almost $200 on a new subwoofer and now i'm not sure what the actual problem is, because if I do replace the subwoofer and the rear speaker, the amplifier will just blow the new speakers and cause a smoke hazard.
Anyone interested in starting a class-action lawsuit? This is clearly a defect.
Old Oct 24, 2019 | 09:34 PM
  #80
Update: MB doesn’t want to do anything still
front passenger door speaker is going now as well.
Old Dec 14, 2019 | 09:53 PM
  #81
r1cardo's Avatar
2014 E350, 2018 GLS 450
Burnt smell
Driver side speaker made a pop sound while listening to music then strong smell of burnt plastic,
I think listening at higher level caused the problem
I usually don’t crank it up. Some comments suggest replacing the speaker won’t solve the problem could be the amplifier. The rest of the speakers still work. the bad speaker will be disconnected tomorrow I can live without one speaker No problem, my worry is they will keep burning.
‘14 E350 ~62k. Any suggestions?
Old Dec 15, 2019 | 05:14 PM
  #82
212swe's Avatar
W124 W212
Same here driver speaker got broken but not burning only started to play bad. Some say that MB W212 original speaker can't handle heat that's why the burning? Going to replace all speakers with after markets no point to buy OEM.
Old Dec 15, 2019 | 07:09 PM
  #83
r1cardo's Avatar
Update from last post:
I removed the driver’s door panel this morning and there are 3 speakers. The 6.5” speaker works fine, the other midrange speaker is the bad one it smells burnt, looks like it burnt internally. No visible melting parts. The tweeter didn't work either But it passed the sniff test.
Just to verify that both speakers don’t work at all I removed the passengers side panel and swap speakers for testing purposes only.
The Driver’s side Tweeter only works on passenger side and the driver’s side mid range speaker didn't work either side.
I think the amplifier needs to be replaced it burnt one speaker and doesn’t Send any signal to one Tweeter. The amplifier is located in the trunk it is easily accessible. I can’t believe dealer charges $2k for troubleshoot and replacement.
Old Jan 18, 2020 | 02:41 AM
  #84
Hello my dudes, I believe my sauga of melting speakers is about to end. Just ordered a new subwoofer off EBay and got it today, and also ordered the side door panel speaker
Here’s the new subwoofer! Someone had an issue with their speaker at the MB dealer, and ended up being covered by MB, but the guy never came back to install it haha. So pretty good deal considering it’s new
Found out the right rear speaker was actually unplugged, previous owner had this issue and dealer I believe disconnected it.
Old Jan 18, 2020 | 08:30 AM
  #85
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
It seems like the 2014s are the only ones experiencing this? Also - the CPO warranty someone mentioned above will cover this (it is in the booklet)
Old Jan 25, 2020 | 01:27 AM
  #86
Speakers installed! Speaker Melting Syndrome is now over
Installed the new speakers! All together $576 installed. Pretty happy considering the subwoofer along from the dealer is $980
Here is it now!
lol, I do not listen to Celine Dion, but it was the only CD and I couldn’t do Bluetooth audio at the same time while recording.
Old Jan 25, 2020 | 08:28 AM
  #87
LILBENZ230's Avatar
Glad you got it sorted - there is no issue with listening to Celine Dion. I've seen her live many, many times.
Old Jan 25, 2020 | 01:10 PM
  #88
goinboardin's Avatar
2014 c300 4matic
My wife's mercedes is doing same thing had to take fuses out to stop smoking speakers
Originally Posted by belarus27
so the problem was with speakers then?
and the C class felt even if comparing to a 3 year old e class?? is that what you saying?
This is obviously a defect in mercedes. They need to have a recall and fix the speakers
Old Jun 4, 2020 | 05:12 PM
  #89
tpdtopcop's Avatar
Saab
I have a new to me 14 350 about a month old. Driving home today very hot smelled something funny and then a buzzing sound from passenger side rear deck. Sounds like a subwoofer possibly? Hasn't done the noise again after driving later the day tho.
Old Jun 4, 2020 | 05:31 PM
  #90
tpdtopcop's Avatar
Saab
All the speakers sound fine. So wondering if it's amplifier or subwoofer? Anyway to check to be sure?
Old Jun 4, 2020 | 07:51 PM
  #91
That is the subwoofer. Same scenario as me. That continues even if the radio is off? if so same as me. check rear passenger door speaker as well
Old Jun 4, 2020 | 07:52 PM
  #92
you can change the balance through the sound menu on the car
Old Jun 5, 2020 | 08:31 AM
  #93
tpdtopcop's Avatar
Saab
Thanks for the reply. I am looking for the correct subwoofer and rear deck speakers along with amp on ebay. Anyone have the part numbers for the sub and amp? Might as well look for the rear door speaker as well. Part numbers anyone. I cant believe this is even happening. I have owned a lot of different makes and model cars other than this being my first MB and I have never ever had this type of problems with car speakers and what not.
Old Jun 5, 2020 | 11:13 AM
  #94
tpdtopcop's Avatar
Saab
Very hard to get that subwoofer out?
Old Jun 5, 2020 | 11:38 AM
  #95
Old Sep 30, 2020 | 04:01 PM
  #96
Bdaw8's Avatar
E350 4matic
Speakers Melting
Had the same problem with my 2014 E350 (less than 60k miles) rear deck speakers and amplifier (crackling/humming noise, burning smell, smoke). Everyone, please file a complaint with NHTSA or the equivalent in your country. These vehicles should not be catching fire. This is obviously a defect and should be recalled....that won't happen if you don't complain.
Old Dec 27, 2020 | 12:54 PM
  #97
Flyboy2000!'s Avatar
E350 Coupe
Hello Everyone,
Just signed up on this forum to find answers as well. My 2014 E350 Coupe was purchased CPO with less than 4,000miles. Warranty expired October 2018. Last week sitting in car ..plastic smoke smell/ loud crackling popping sounds and toxic smell I turned and saw smoke rising just above the passenger side seat belt extender. The car was off all nav and sound off. I was just sitting in the car on a phone call.
I immediately drove to dealer who was 7 mins away and dropped car off with service advisor in Costa Mesa California. Called back said speaker was shorting.. ($400 parts and $600Labor) I asked him to have the technician check all the speakers and system for error codes. He calls back a few hours later to say that I was right..another speaker as well(see video)..New estimate ($400 parts and $1000labor) Right Rear Tweeter and Right Rear Woofer.
They would be kind enough to discount 15 percent with a coupon and suggested I reach out to the speaker manufacturer. I declined!
I bought the speakers from another dealer and had a qualified car stereo shop install. Once they were done, crackling sound AGAIN! Stereo guy says its the Amplifier,or should I say..the Control Module. This part alone (reconditioned) is $1500. I can not power up the car, the short starts as soon as the door is unlocked.
Does anyone have any ideas. My dealer seems to have told me to fend for myself unless I have deep pockets.
How can I get it to where I can at least use the car to drive? Is there a fuse I can pull? If so Where? Any options of not spending $1500 for a remanufactured Amplifier?
Thanks for any suggestions.
2014 E350 Coupe, currently 47,000 miles. AMG
Harmon / Kardon Sound
File Type: mov
Old Dec 28, 2020 | 04:56 PM
  #98
LILBENZ230's Avatar
The amplifier is the problem, from what I understand. Amplifier part number changed later and only the 2014s seem to be the issue. Replacing speakers won't help, you must replace the amp. Either factory or aftermarket.
Old Dec 29, 2020 | 12:56 PM
  #99
E350 Coupe
So I pulled fuse #67 in the trunk SAM module. Hopefully that is the correct one. At least now I can drive the car.
Can you tell me what the NEW part number is? If I were to buy one on EBAY I do not want to buy a used ( bad)one that may have the exact same problem, and burn out more speakers or cause a car fire!
If I were to go with an aftermarket amplifier what specs am I looking for?
I tried to pull the wire harness off the control module ( amplifier) and could not even figure out how to do that! Had some weird Purple latch on it (?)
Thank you
p.s. a MB dealer reconditioned amplifier/control module is $1500.00USD
Old Dec 29, 2020 | 01:21 PM
  #100
LILBENZ230's Avatar
Well these things are not inexpensive, but dealer pricing is always ridiculous. I am not sure the new part number can be just swapped in without issue - there may have been more changes than just the amplifier. I also don't believe it will be cheap/easy to just put in an aftermarket amplifier into this system.
