HELL of a Predicament !!
Of course, there is limited room to work, maybe 12", and to see what's going on , but I can see past the plastic jack pad to where the threaded part of the jack goes thru the metal. I could cut the threaded part of the jack and push it up but I don't know where it would go. At least I could remove the jack and drive the car. With covers under the car, I can't see if there would be a way to retrieve the sawn-off part and I don't think I really want it in there rattling around forever. There doesn't seem to be anything solid to pry against in the area of the jack pad so no leverage to pry the jack screw out.
Suggestions??
As far as getting your jack out...patience, a sledge, some pry bars, a torch, something to cut it off, not sure without seeing it! Good luck though.
The plastic jack pad fits into the hole in the sheet metal somewhat like a grommet with plastic also on the inside. I used a narrow chisel to cut the plastic away from the metal, and that left room for the jack screw to come out, quite easily at that.
Quite an adventure for the day. And now on to the first oil change.
I did get the oil and filter changed. Also found that jack point in the center front of the car and made a wood insert for my floor jack head so that I can use the center jack point in the future if needed. Not much room under the car unless you really jack it high.
My plan for future changes is to purchase an oil pump and pump the oil out the dipstick tube. Much easier, not as messy, don't have to crawl under the car and I am confident that as much oil will be removed with the pump method as the drain plug method. I was pleasantly surprised to see almost no oil in the filter housing when I removed that and no spills.
I'll post some pics tomorrow of the jack pad.
If you have shavings/debris at the bottom of your oil pan (pretty rare these days), they would be stuck there - because if they're suspended in your oil they would be sufficiently filtered during normal circulation.
With CPOs and MB extended warranties, there'd be no way for them to calculate the appropriate time to have damage occur by using the topside method...so I think you're safe! To each their own though...I really like the topside method...I just pump up the system and walk away, come back later and swap the filter & refill. No dirt, no raising the car up, and no oil mess anywhere!
As for metal particles in the pan, it is, of course, possible that you may be able to detect them in the pan after pulling the plug, but I would think that either particles would flush with the oil rushing out, or would remain in the pan out of sight. If the particles flush with the oil, you can still look in your oil drain pan for their presence.
I'm voting with Fosterelli on that one.
I've got some old hardwood flooring that I put some rubber on and use that to protect the bottom of the boxed unibody sections then just jack it up. A little harder but a lot less drama than the ski adventure.
even with thick oil, metal is not going to get lifted into the engine. Some of the alloys might, but the idea that you could suck them out with the extremely low viscosity stuff in these engines is just silly.
Fortunately, the design of our oil filters makes it easy to pull the pleats apart and see what the oil pump's been able to pull up to the filter.
Obviously more crap is going to fall out the bottom than get sucked out of the top.
The idea that "the dealer does it, so it must be the best way" is not universally true and often downright false.
The topside method is not new - just new to some people on here. No one is trying to "suck" crap out of the top. It's an oil change. As long as you're maintaining your oil change intervals properly, the filter does all of the work your car needs as far as particulate removal. If something is stuck in the sump (shavings/particles) you don't have to worry about it anyway. If it does circulate, the filter catches it. Oil goes from the sump to the filter, then to the engine and back down to the sump.
Filters average a nominal 25-30 microns..that catches very small particles. Human hair is about 45-70 microns. The human eye can see about 40 microns. And filter efficiency ratings are pretty high these days.
Your oil change is there to remove the old oil and change the filter. It is not designed for you to remove anything else (like junk in the pan). The lubrication system of your car takes care of that.
You're not pulling any crap from the bottom vs. the top. It's all in your filter, or stuck somewhere not hurting anything. But for those who are concerned about it, feel free to climb under your car and do it the hard way. But I bet your engine won't be more protected than the topside guys.
I'm also willing to bet all manufacturers of topside oil change vehicles (including Mercedes) have conducted used oil and filter analysis of both methods, prior to implementing the topside process. They wouldn't want their warranty claims jumping because the topside provided less protection. MB is making 2 million cars a year - can you guess the costs if they didn't do their homework first? I guarantee they put more thought into this than you can imagine, including engineering studies and engine tear-downs for wear inspections.
The dealer way certainly isn't always the best way, but usually is - because they are factory-trained, have access to information and equipment you don't, and do it all day long on the same types of vehicles. So while they aren't always on point, they are getting it right far greater than most independent shops and backyard mechanics...not to mention DIY'ers. Their exposure to countless MB engine services, repairs, overhauls, troubleshooting, diagnostics, etc. on a daily basis makes them the experts, not us.
