Sponsored by: CARiD
285/30/19 on E350 Sport?
Old Dec 25, 2016 | 07:30 PM
socci's Avatar
2011 E350 4MATIC Sport
I read 285s can fit on the w212, but does that also apply to the sport? I believe the sport is slightly lowered and not sure if it makes a difference when it comes to rear wheel width. Can someone tell me the widest 19in tire that can fit front and rear.
Old Dec 25, 2016 | 07:46 PM
threeMBs's Avatar
Only MBs - the best or nothing
255/35 front and 285/30 rear (same as E63) without any issues on any W212.
Old Dec 27, 2016 | 12:14 PM
J.M.G.'s Avatar
'17 C63S Estate (S205) / '14 CLS 550 SB (X218) / '17 E220d (S213)
I had SL R231 rims on my 2012 E550 4matic.
255/35 R19 on 8.5x19 ET34.5 front
285/30 R19 on 9.5x19 ET48 rear
Fits perfectly.
(ET = offset).
Attached Thumbnails 285/30/19 on E350 Sport?-1.jpg   285/30/19 on E350 Sport?-2.jpg   285/30/19 on E350 Sport?-3.jpg
Old Apr 11, 2017 | 04:12 PM
socci's Avatar
Anyone know if a 19x10 et55 285/30/19 will rub?
Old Apr 11, 2017 | 06:45 PM
berti_00's Avatar
2016 Cls63s AMG
if lowered on Vogtlands do you guys think these would work without any issues
19x8.5 ET35 245/35/19 would 40 profile work here?
19x9.5 ET35 275/30/19 would 35 profile work here?
Old Apr 12, 2017 | 08:46 AM
Diesel #2's Avatar
2016 E 250 Bluetec
Those sizes are too large, they will not fit.
I am running pretty much the biggest tires you can run on a W212 without rubbing and the ride is more comfortable than my factory 17s. But that is probably because the 17s were run flats.
235/40/19
265/35/19
Old Nov 7, 2023 | 07:10 PM
AndyAtari's Avatar
e350 2010 coupe
do you guys have any idea if
Front: 7.5Jx19 ET44
Rear: 8.5Jx19 ET52
will fit on 2010 e350 coupe (rear wheel drive)
suspension on it is stock:
Agility Control damping system
Strut front suspension & 5-arm multi-link rear suspension
Also what size tire do you recommend I go with to avoid rubbing?
Old Nov 7, 2023 | 07:11 PM
AndyAtari's Avatar
e350 2010 coupe
235/40/19
265/35/19
Those are the exact sizes I was thinking of running.
What specs are your mags?
Old Aug 17, 2025 | 10:25 AM
Kali4278's Avatar
2011 E350 4matic
19” Fitment
I have a 2011 E350 Sport and thinking about switching over to 19x8.5 inch wheels all around. I would ideally like to go with a 255 tire and if possible, maybe 265 but not sure if those will fit and not rub. Anyone have suggestions on the tire size I can use if I want to go wider than the stock 245s?
Old Aug 24, 2025 | 11:02 PM
ColonelKlink's Avatar
2014 E550 4matic 180k Mi
245/40-19 will not work on my W212. I changed back to 245/35s. Yes, slightly different W212, but that's only related info I can share. glwsearch.
