change 7222.9 transmission fluid is it gonna miss the conductor plate
I have an E300 w212 2010 model with 115k miles on it, I am the second owner and planning to get the transmission serviced some technician said to me if the first owner didn't change the fluid I shouldn't do it because it will miss up the transmission and it will act bad, what do you think should I do it to reserve the condutor plate and the longer the life of the transmission or not?
At the end of the day, this $8000 decision to service or not is personal...
Are your gears slipping ?
is your tranny acting up?
DON'T USE MISC. "COMPATIBLE" ATF (RED/BLUE).
Your mechanic can take a sample and warm it up to check if the level is OK. If he asks you how that is done, RUN.
Here is someone taking a sample,
Old transmissions that had adjustable bands were noted for slippage. If they slipped for too long, it was too late for a fluid change. Our transmissions do not use bands.
Honestly, if I was a technician in that situation not knowing the service history, I too would walk away from the $600 job at the risk of having to replace the tranny if it fails afterwards.
https://bobistheoilguy.com/forums/th....388071/page-2 See post #29
There are no 'flush' machines that I can find that forceably move fluid through the valve body, or other parts. None operate without the engine running, driving the transmission pump to produce line pressure and circulate the ATF.
My OPINION is formed in large part by conversations with my mom, who worked in a garage that repaired and rebuilt lots of transmissions. She did not do the mechanical work, just worked in the office, but heard many, many conversations between transmission owners and the garage owner, who hoped that their transmission problem could be fixed by replacing the fluid. The garage owner could tell with great certainty which jobs might tolerate new fluid, and which would not. The ones that he thought would not tolerate new fluid were just worn out anyway, and adding new fluid would just add that cost to repairing the transmission, which still needed to be done. But many customers insisted on new fluid, even against his advice. Either way, the garage made lots of money. Worn-out bands were a universal problem with those transmissions. From that experience, I conclude that if your transmission has noticeable difficulties, flaring on shifts, failure to shift, etc, you need to repair the transmission; otherwise, replace the fluid.
On the flush machines. I must admit I have not seen one personally in decades, but I recall when a mechanics was flushing "live in front of me" a family Ford Fairlane station wagon back in the days until fresh fluid came out. Too far back to recall if the engine was ON or OFF.
I think most people highlight the difference between the procedure to be clear in case someone has the way to forcibly force fluid through the transmission. I think most people use flush/drain interchangeably.
Now, there are two practices I have seen so far
1 - Disconnect the return line from the radiator while adding fluid through the drain hole (engine running, of course) until clear/fresh fluid comes out.
2 - Connect extremely low-pressure air through the conductor plate and let the oil come back from the torque converter with oil. It is a very slow process, in hours. You can see SPR Automotive MB specialists doing so in several of their YouTube videos, and also read about the adapter on another thread.
As mentioned above, new fluid doesn’t destroy a transmission it lets you know that the transmission was already failing. I will echo that if there are no issues, a drain and flush will (likely) be fine.
some shops don’t like to take the risk because some customers think that the fluid will fix the problems they already have, but if you absolve them of the liability, you should be able to get whatever you need. Fluid is not for fixing problems, it is for maintenance, in the most general sense
Here is Tassos describing the drain through the coolant lines near the radiator
