Engine Code 0496 - Either the Gas Cap or Purge Valve?
2010 E350 here.
Check engine light came on, the code was P0496: EVAP Flow During Non-Purge Condition.
From research, it could be the gas cap not fitting tightly, or the purge valve needing to be replaced. I checked my gas cap and it didn't seem to click the way it used to. I can get one in a few days for $30. But if it's the purge valve, that's a new territory of installation for me, and the part is about $65.
Does anyone have any experience with this? Or and thoughts to share?
Thank you in advance!
It's still throwing code 0496. I attempted to clear the code via the Torque app through my bluetooth ODBII reader, but the CEL and code are still present.
I've read it takes several to tens of engine cycles for it to clear, if it's truly a gas cap problem. Otherwise, it will be a purge valve issue...
Somehow, the bill came out to be $398 total, so got a little ripped, but not as bad as it could have been!
They detected $1200 worth of optional repairs:
Motor Mount: 3 mounts $991.00
Camshaft Oil Seal: Rear centrifuge cover $207.80
Getting a little worried at the thought of the maintenance cost. I was hoping I could do Service A&B religiously and get by to 160k miles or so. I'm just past 80k and they keep finding $500-$800 worth of opportunities every other service!
Thanks for giving me an idea of what to expect for those other two maintenance items. You'll probably save me big! The MB Dealership guys said that those 2 leaks were "suggested" items for the near future. In my mind that equated to 90k service. But if you have any thoughts on how soon to take care of small leaks like that, I'm open to hearing it.
Thanks again, you've been really helpful.
