My 2012 E350 won't start
As for CPS, either camshaft or crankshaft position sensor. I think those normally throw a code. Is the CEL on? Even if it's not on, you might be able to take it to an auto parts store and get the car scanned for any old codes.
Are you sure the main battery is charged? What's the voltage? Take it out and get it loaded test, could be a bad cell. Or you have a bad alternator, but if you take it out and charge it up, it should last long enough to drive a few miles. You could always take it out and bring it to an auto parts store if you don't have a charger.
Search dyno mode and you can put your car in it and see what the alternator is charging.
search dyno mode? Can you be a little specific?
Follow those instructions, look at vehicle data. Start the engine and it will show how many volts the alternator is charging at. You should see anywhere from 13.5-14.5. When my old W211 had the red battery warning screen, dyno mode showed 11-11.5v indicating a clear problem with the alternator.
It is a charging error, you need to address the real cause before replacing the battery again.
