Sponsored by: CARiD
2013 E350
Old Apr 18, 2017 | 10:43 AM
n_akkawi's Avatar
2013 E350 sports
2013 E350
I have 2013 E350, that makes noise in rear while entering the garage. I have to go under the building complex to the garage, and it is a steep grade, and the noise seems like creaking noise, this happen 90% of the time. I asked the dealer and of course, they could not replicate it so I am stuck trying to figure out were this noise come from.
Old Apr 18, 2017 | 11:26 AM
belarus27's Avatar
2010 e550 p2
record a video for dealer.
does it happen when u brake? suspension component?
Old Apr 18, 2017 | 11:42 AM
blegthbloo's Avatar
2013 E550 4Matic
Do you have the pano roof?
Old Apr 18, 2017 | 06:35 PM
cetialpha5's Avatar
Yeah, sounds like the pano roof. The bolts get loose, only happens when you go over a ramp at an angle so the body flexes. If you hit it straight on it doesn't make the noise. Someone had a DIY video on how to fix it. Use loctite on the bolts so they don't get loose again.
Old Apr 25, 2017 | 10:50 AM
n_akkawi's Avatar
2013 E350 sports
My 2013 has a pano roof. This noise does not happen when I brake.
Old Apr 25, 2017 | 11:11 AM
cetialpha5's Avatar
Then it's probably the bolts in the pano roof. When turning into the garage, is it at a steep angle or is there a ramp? The body ends up flexing at that point, think of a box and twisting it. The flex makes noise when the bolts are loose. Happens when one wheel is higher than the other.
Old May 2, 2017 | 05:56 PM
n_akkawi's Avatar
2013 E350 sports
So what do I do, live with it, or can it be fixed?
Old May 2, 2017 | 07:22 PM
cetialpha5's Avatar
I think someone fixed it.
https://mbworld.org/forums/e-class-w...ml#post7064544
