Sponsored by: CARiD
problem with air con
Old May 4, 2017 | 03:30 PM
energymad's Avatar
2011 E250 CDI BE SPORT
this morning had my air con on ,set at 21c which is pleasant and warm and sent my car to the garage to have a few filters changed including air filter but since I have got the car back I have either hot or cold air with temp differences noticeable from 25 degrees c up to 28 degrees cent and the temp difference when set at 26degrees and changed up to 27degrees is huge ,now im driving an e 250 cdi be sport and to the best of my knowledge when set at 21 degrees it blows out air at 21 degrees c is this correct or is that the temp setting for the car inside ,I always thought it was the air coming out of the vents temperature setting and if so what could the garage have done to damage the air con please help
Old May 4, 2017 | 05:38 PM
Lolxa's Avatar
2010 Mercedes E550 4matic Sport P2, Driver Assistant, Night Vision, Parktronic and Panorama Sunroof
Basically how climate control works in vehicle is a 2 inputs coming from 2 sources of thermal (1 heater, 1 cooler (AC)) then join up into a Y and exit 1 vent. At the conjoining point at the point intersect there is a electronic flap that is controlled by user that adjusts the angle (more heat or more cool) and then there is a thermometer within the vehicle that tells it to stop blowing air once the desired temperature is reached. The air that is blown out is probably not what you set it at.
Old May 5, 2017 | 12:41 AM
energymad's Avatar
thanks for the reply but my problem is that whenever I turned on my ac at 22 it was always warm as in the air coming from the vents and after yesterday being at the garage now its cold air and only gets warm at 25 so any ideas what might be causing that all of a sudden to happen
Old May 5, 2017 | 11:17 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
There are two wires you disconnect to get to the air filter when removing the panel - one is for the footwell light and the other might be for something with the AC system - not sure at the moment. Worth checking that.
However, if you use manual control of fan speed and turn temp way up and get heat and way down and get cold, that's a good sign. Check that vents are open. Otherwise, you may be stuck taking it back to them or just getting used to the new setpoint.
Old May 10, 2017 | 04:25 PM
energymad's Avatar
found the problem too embarrased to mention but thanks to those who helped
Old May 10, 2017 | 04:27 PM
Lolxa's Avatar
This is a growing and learning community, there's nothing embarrassing about learning about our cars.
Old May 10, 2017 | 04:30 PM
energymad's Avatar
im driving mercs for yrs but im at a loss with my newest car only finding out what everything is for
Old May 11, 2017 | 10:05 AM
blegthbloo's Avatar
2013 E550 4Matic
Yeah it's not like we're gonna track you down and picket your house for making an embarrassing mistake on the internet lol... you can share with us from the comfort of your home and heart boxers and bunny slippers. We won't judge you, since we're all doing the same thing.
