Sponsored by: CARiD
--will this ET work for front w212--
Old May 20, 2017 | 05:14 PM
berti_00's Avatar
2016 Cls63s AMG
ET43 9.5 all around.. Will be lowered on Vogtland springs later
Front 245-40-19
Rear 275-40-19
Thoughts from the wheel gurus
Old May 21, 2017 | 12:39 AM
SweetJazz's Avatar
2016 E350 Sport
I rubbed with a 20" x 8.5" +35 and a 245/35-20 tire. I'm thinking the 19" x 9.5" +43 with a 245/40-19 tire will rub. The brand of tire is also critical. The Michelin Pilot Sports have a rounded sidewall so rubbing can be less.
Old May 22, 2017 | 09:19 AM
threeMBs's Avatar
Only MBs - the best or nothing
Front 245-40-19
Rear 275-40-19
Front wheels will fit (barely) a stock hight car, but once lowered, no idea.
Rear tires will definitely not fit at all. Front tires will badly rub.
Old May 23, 2017 | 12:49 AM
berti_00's Avatar
2016 Cls63s AMG
I am going to stick with 19x8.5 et38 19x9.5 et43 as far as tire size goes not sure yet
Old May 23, 2017 | 01:34 PM
berti_00's Avatar
2016 Cls63s AMG
I just checked the offset on my current wheels with a mirror
Rears are 18x9.5 Et45 275/35/18
Fronts are 18x8 et42 245/40/18
So new set up should be no problem at all I am assuming
19x8.5 front Et38
19x9.5 rear et43
Old May 23, 2017 | 06:10 PM
threeMBs's Avatar
Yes wheels will fit easily. Its the tires from the original post that won't (especially the rears).
Old May 23, 2017 | 07:53 PM
berti_00's Avatar
2016 Cls63s AMG
what tires should i be looking at for the best results
19x8.5 front Et38
19x9.5 rear et43
And I will be lowered on Vogtland springs
Here is the wheels
--will this ET work for front w212---img_20170523_144810_276_zpsubuyvly1.jpg
--will this ET work for front w212---img_20170523_145000_760_zpsnqwbws9e.jpg
Old May 24, 2017 | 10:32 AM
threeMBs's Avatar
19x8.5 front Et38
19x9.5 rear et43
Here is the wheels
255/35 with 285/30
Old May 24, 2017 | 06:28 PM
berti_00's Avatar
2016 Cls63s AMG
255/35 with 285/30
Can I instead do 245 40. 275 35? Hate to have such low profile tires
Old May 24, 2017 | 09:22 PM
RA72825's Avatar
The difference in sidewall between each of those tires as suggested and what you are suggesting is .4" , not saying that sidewall does not matter, but just so you know what the difference is.
Old May 24, 2017 | 09:52 PM
berti_00's Avatar
2016 Cls63s AMG
i just am not sure how much will vogtlands lower the car they say 2 inches.. maybe i should lower it first than figure out the tires or what do you think?
Old May 24, 2017 | 10:10 PM
RA72825's Avatar
That's s big drop. Is that from a luxury suspension or sport? Sport is already .7"'lower than luxury. You may want to drop it first and get some actual measurements once it settles. You may be forced to go with a lower profile tire.
Old May 24, 2017 | 10:32 PM
berti_00's Avatar
2016 Cls63s AMG
i have sport package.. going with vogtland springs
