Sponsored by: CARiD
Rattle sound from underneath
Old Sep 24, 2017 | 09:32 PM
Pristine's Avatar
2014 E350 4Matic
I have a 2014 E350 4Matic and it has a rattling sound coming from underneath when i drive at slow speed on uneven road surfaces. When I roll the windows down, it seems to be coming from under the driver seat . It is a metal to metal vibration kind of a sound. Maybe loose heatshield over the muffler?
I took it to a local non-reputable shop close to my home so they could raise it and see if there is anything obvious. The shop guy and i both looked under the car and nothing seemed loose including the muffler. I'm planning to take it to a Mercedes indy shop this week to get it checked out.
Has anyone had any experience with rattling sound coming from under the car? It would be nice to pin-point to any known problem areas in advance instead of letting them spend time/money searching. Please let me know if you have any ideas.
Old Sep 25, 2017 | 09:29 AM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
I haven't experienced anything like that. Last time I heard a rattle on a Mercedes was my W202, it was a loose fan/engine bearing or something. Fixed it and quiet again...
Now, direct injection "ping" and super-loud compressor/fan when A/C on...that's another story! lol
Old Sep 25, 2017 | 09:38 AM
Pristine's Avatar
2014 E350 4Matic
It is definitely a rattle coming from the bottom area around the exhaust...like something is loose. So embarrassing coming from such a nice looking car.
Old Sep 26, 2017 | 01:30 AM
belarus27's Avatar
2010 e550 p2
Exhaust pipe rubbing agaunst exhaust tip? Inside the tip...
Old Nov 2, 2017 | 01:04 PM
Pristine's Avatar
2014 E350 4Matic
The exhaust tips seem to be a snug fit with pipe.
I took it to an indy MB shop close to my work...left the car there but they couldn't figure out and said they did not hear any rattle. They kinda seemed shady so I didn't argue much and not sure if they even paid attention when I said that this vibration/rattle is only heard at low speed less than 35 mph. When I pull in to covered garage at my work...the noise can be heard even louder as I cross over the joints.
Im afraid I may have to pay up to the dealer to diagnose and hopefully get fixed.
Old Nov 2, 2017 | 04:07 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
2014 e550; same rattle sound too. Took in for service and did road test, sound disappears.... really weird. The slightest bump would start it. I have airmatic. My next service will be taking to a different dealership. About a few months tho. Will check back if you don’t.
Old Nov 2, 2017 | 05:14 PM
Pristine's Avatar
2014 E350 4Matic
I've been hearing this rattle sound every day and it is very annoying in an otherwise quite cabin. Both places I've been to were unfit to identify the root cause which is probably going to be a simple fix. I've been avoiding going to the dealer so far because of time and cost. I'm out of warranty at 70k+ miles.
Old Nov 2, 2017 | 07:08 PM
Abrown3mtg's Avatar
2010 E550 4Matic Sport P2
Put the car on a lift while it is running and idling in gear. get under the car and see if you can pin point it... a stethoscope will help. I had the same issue in mine. Checked all the obvious spots (wheel bearings, brakes, etc). Mine ended up being flakes of rust in the driveshaft. Very odd as the car was at about 40k miles at that point.
Old Jun 27, 2019 | 08:19 AM
MERC17's Avatar
Mercedes 2014 coupe
2014 coupe rattling
Could anybody help,driving me crazy,rattling coming from under front seat when I go over bumps rough
Terrain,I have had car up on ramps nothing loose
Old Jun 27, 2019 | 03:28 PM
BigRob_NH's Avatar
2001 E320 4Matic (SOLD), 2009 E350 4Matic (SOLD), 2016 E400 4Matic
My old W210 with a ton of miles (150K+) had the Catalytic converter go. It was rattling like a baby rattle. Seems unlikely with these newer cars but just wanted to put that out there.
Old Jun 29, 2019 | 07:58 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
There was a pebble rattling around between the rear exhaust tip's outer cover and the pipe itself on our Wagon. You can check it by rapping on the exhaust tip with your hand and hear if there's something in there between the two layers of metal. Had to keep rapping on it for a few minutes so the loose pebble to fell out.
It's not uncommon for small rocks and pebbles to find there way in-between heat shields in the undercarriage and make rattle noises.
Old Nov 9, 2021 | 11:56 PM
Ms1974's Avatar
2016 A250
Did you find the underlying cause of the rattle?
I have the same issue and I’m being told I need to replace both front shocks - which seems absurd for a car that’s only done 45,000km
Old May 14, 2024 | 04:23 PM
HueManGod's Avatar
2014 w212 4matic
I've had the same issue, and i've taken it into 2 shops and neither has found the issue, and I know it, they weren't taking my complaint seriously. I haven't been able to find any information about this anywhere. But the scenario you've explained is exactly what I'm dealing with, and would like to find out how to fix it.
Old May 14, 2024 | 04:43 PM
Abrown3mtg's Avatar
With the car on a lift, I was able to see where the driveshaft to the rear end was able to be separated from the yoke at the back end of it by removing a few bolts. Once I did so, I was able to drop the drive shaft a bit to and angle I could insert something and brush out what gravity did not resolve on it's own. Good luck. I am curious if this is the solution for you as well. Please report back with the results.
Old Dec 17, 2024 | 05:11 AM
Braicu Serban's Avatar
cls 350 2014
Hello i have a cls 350 4matic 2014 and exaclty the same sound,did you solve it?
Old Dec 18, 2024 | 12:42 PM
HHS550's Avatar
2019 AMG GT
Check your heat shields above the mufflers. The tab on one of mine had broken off and that was the cause of my vibration. Good luck.
Old Dec 18, 2024 | 01:11 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
I have had that situation twice. Once was on my rear subframe had rusted away from the rest of the car the other one was when I somehow contacted something under the car and my exhaust pipe was rubbing up against another piece of metal underneath the car
