TPMS - No Wheel Sensors
Just over a year ago the right front TPMS sensor went missing. Dash displayed correct pressures for the remaining 3, and showed TPMS Sensor Missing for the right front. decided to live with it until the tires needed to be replaced.
Fast forward to Sat, 10/28: Brand new Michelin Pilot Sport A/S 3+ installed by local tire shop. Since one was dead I decided to have all 4 TPMS sensors replaced given they are about 7 years old. Tire shop used Schrader brand "EZ-sensor", P/N 33500.
Initiated the reset through the dash, and the yellow tire light remained on of course. 8 ish miles later: "Tire Pressure Monitor Inoperative No Wheel Sensors". Yellow tire remains on.
It sure seems obvious to me. System was working fine before the tire and sensor change, and now it can't find any sensors.
The quick question is this: does the TPMS system need to be reset using SDS? I've read a dozen TPMS threads here and I haven't seen a single thing that said SDS will solve it.
Many thanks,
Dan
And thanks for confirming the SDS question.
Dan
Many thanks,
Dan
By this shop there are two frequencies on the sensors that they read with the tool but based on what happened there must be another one in use in my car.
I had a conversation with Schrader tech support a little while ago. As I mentioned above, the tire shop used Schrader sensors, #33500. According to tech support that sensor, which is a "programmable" sensor (it broadcasts in 3 different frequencies, and other parameters) the installing tech must program it with a programming tool to the vehicle. He further stated that, according to his documentation, the 33500 cannot be programmed to my 2011 E550. The Schrader tech further suggested that their model 28214 sensor be used; it is a direct replacement for the OE and is pre programmed. Finally, he confirmed that if a sensor is programmed, or pre programmed correctly the vehicles TPMS system does not need to be "reset" using factory diagnostics (AKA SDS).
I'll be stopping by the tire shop this evening.
To add insult to injury, the tire shop charged me 3X the price for each sensor. The 33500 is available at local stores and across the internet for about 50.00 Ea. They charged me 150.00 each. Ouch. My own fault, while I price shopped the tires I didn't shop the TPMS sensors. Regardless, I've sent their corporate office an email.
Dan
The day I had the wheels put on, the car did display a tyre pressure low message, but I simply restarted the car, drove it, and it hasn't reported any errors since. I gather the car had to calibrate/adjust.
I'm sure someone knows the facts here in the forum...
BTW, the Michelin Pilot Sport A/S 3+ are really nice, much better than the OE Continentals. I also had all 4 road force balanced - well worth the 25.00/per tire up charge.
