Bi-xenon headlight question
And the ballast is a separate entity attached to the headlight housing using screws. If you get a new one, it will need SCN coding.
I've also noticed that the newer OSRAM D1S CBI are rated at 6000K instead of the older 5500K which I had.
OSRAM Bluer is brighter. Technology is evolving. Check the video below. It confirms OSRAM bluer is brighter as per luminosity (LUX).
Standard 4300K: 315 LUX
CBI 5500K: 340 LUX
CBH 6000K: 415 LUX
CBB 7000K: 460 LUX
the video included does a fantastic job of showing you some of the main players - and nice that they CBBs have come down in price - just be sure to get them from a rep dealer...
Cheerrs
JPC
Sadly I think all the bi-Xenons have that V shaped haze in the lense...it can be cleaned out - from the inside. I talked to an expert headlight restorer - said he can do it but it takes time to pull out the entire headlight to do it right and said it will return in 1-2 years so to be aware of that...
I should of taken pictures of all the various bulbs I tried...
D1S CBB - was my final choice...(knowing is 1/2 the battle - I did not want to spend the $150 (when I first looked they were $250!!) ish for them cuz I thought they were expensive - I prob spent $400 just testing $30 here $50 there)....
Cheers
JP
As for the color temperature. I'm going to stick with 4300k when it's time to do mine. While the higher color temperatures may be brighter, there was a reason the manufacturers picked 4300k, that's the best temperature in general for the eyes. Higher color temperatures produce more glare for oncoming drivers and visibility is reduced in bad weather. Also because they're not factory, when they're too blue, the police can stop you because it's not OEM or DOT approved.
