Sponsored by: CARiD
Learning 7GTronic - horrific learning algorithm
Old Mar 22, 2019 | 01:50 AM
pezzy669's Avatar
'11 E350 4Matic Sport
So only reason I am posting is that I had an '09 C300 with the 7GTronic that behaved much better than the one in my '11 E350 4Matic.
I have performed the reset multiple times and the transmission works well and is responsive for about a week then just goes back into its lug around town mode at 1100-1500RPM. Leaves me dead in the water many times per day waiting for torque to build, if I garner a downshift I get far more acceleration than needed. There is ZERO in between - it's either lugging along trying to go or a downshift and huge squirt of forward momentum beyond what was requested.
I never had these issues with my C300 with basically the same transmission (albeit non-4Matic) under same driving style. Am I doing something wrong here?
Old Mar 22, 2019 | 09:23 AM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
They should be basically identical, maybe with slightly different programming. Any idea if you can get it scanned for codes?
Old Mar 22, 2019 | 10:16 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
7G had update between the years and that is when from "once in lifetime" service they went to intervals. From what I noticed between my 2008 and 2014 models - filters are having different media, even the shape is the same.
Coming to learning process - I ditto scanning the car.
Computer adapts the shifting to your driving style and sounds like something is out of wack.
Old Mar 22, 2019 | 10:20 AM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
Just a thought.
Are you sure it's transmission? The gas pedal has a position sensor (drive by wire) that can sometimes get "lazy". This can cause a lag between the pedal position and what the PCM is commanding to the engine. If you have a scantool to access vehicle modules you should be able to see specific position readings. A generic obd2 may be able to at least give you throttle body opening position to try to gauge pedal vs throttle positions.
Old Mar 22, 2019 | 11:35 AM
DubVBenz's Avatar
The update (at least on the W212) came in 2012 MYs though and was branded "7G-Tronic Plus", so I think his is basically the same as his W204.
Old Mar 25, 2019 | 11:05 AM
Arrie's Avatar
This issue has been discussed in this forum a MILLION times. There is nothing wrong with your car other than MB built it to behave like it does. That driving habit learning SUCKS a big time and there is only one fix for it. Get a Spring Booster (or Paddle Box or something like that.).
My first MB was a brand new 2011 E350 and it had this problem. I now drive 2010 E550 and it has the same problem but I installed a Sprint Booster and it takes care of it all. $300 but you will NOT regret this investment, guarantee it.
Old Mar 25, 2019 | 03:07 PM
pb39374's Avatar
2010 E350 4Matic sedan
What's your overall experience with the Sprint Booster? Any risk of it messing up the car? the installation looks real easy.
Old Mar 25, 2019 | 05:04 PM
Arrie's Avatar
Best money I have ever spent on a car after purchase. SB really works well and installation is super easy. I drove the car without it until warranty ran out so MB cannot blame any issue on SB if any would arise. I have driven about 2 1/2 years with it now and there has been no issues at all. It has many settings allowing to set it for aggressiveness you like.
Old Mar 28, 2019 | 11:00 PM
pb39374's Avatar
I just got the sprint booster tonight. It took me not even 10 minutes to hook it up and put the pedal back together. I took it for a test drive and I like it. I think Race 1 is the setting I will use for daily driving. What settings do you like? I have the 2010 e350 sedan.
Old Mar 29, 2019 | 05:41 PM
Arrie's Avatar
Great you like it.
I have mine on red 3.
Old Mar 29, 2019 | 08:31 PM
ChrisB's Avatar
1999 SL 500 & 2011 E 550 4Matic
Sounds like a fun toy ... where is it installed? Pics?
Do you get better than stock performance ... or just defeat the bad learning habits of the transmission?
Old Mar 29, 2019 | 09:17 PM
Arrie's Avatar
All I hear is you don't get better performance but it sure feels you do. It eliminates the gas pedal lag time that bothers these cars badly. It takes off from stop way faster because of it.
SB is a small plastic piece that mounts on the gas pedal where the wire harness connects to, i.e. you connect this SB module to the gas pedal and then the wire harness to the module. For installation you need to unscrew two nuts that hold the gas pedal on floor.
From the module you have a wire with a small control box with selector buttons in the end of it that you glue with 2-sided tape somewhere you want. You can select no effect or then several different modes that give you different behavior. You can use it to give very mild aggressiveness up to very strong.
Sorry I have no pics.
Old Mar 30, 2019 | 05:44 PM
Peachy's Avatar
2010 E550
If the transmission learns your driving habits, why doesn't it adapt to a sprint booster. Will the sprint booster become less effective over time because the transmission is adapting to what it thinks is an overly heavy foot?
Old Mar 30, 2019 | 09:29 PM
Arrie's Avatar
Yes, the transmission still does the adaptation but SB can be set so aggressive it takes care of it. That is why I use my SB at the 7th highest level. That is high enough for me. But I have 6 more aggressive levels to go if I feel so.
