Help Starter issues engages but wont disengage
Thanks,
Before assuming a starter replacement is needed, a check could be at the connector to the starter. If current always appears from ignition to the solenoid then I'd figure yes time for starter replacement. If current is intermittent I'd look at starter relay and or current from ignition switch itself.
Generally it's a starter issue but just wanted to highlight that verification is good before buying parts.
Solenoids can sometimes be replaced separately but the starter still needs to be removed. Typically though not worth the hassle, most times the entire unit is replaced.
When you buy a starter it almost always comes with the solenoid.
Thanks,
The starter solenoid mounted to the side of the starter is just a high power relay. It has a heavy duty copper braided wire supplying the direct battery power to the starter motor.
I regret checking on this but i think the engagement of the gears happens with the motor starting to turn and then the inertia of the gear wheel making the helical motor shaft turn in the gear and push it in connection with the flywheel gear.
It seems your gear connection is not happening so you need a new starter.
Edit:
I must take this back as I now think the gear engagement happens thru the solenoid moving the gear but in any case it seems you need a new starter.
Thanks,
Thanks,
You mentioned that the starter has already been replaced once. Rebuilt or new oem? Sometimes the replacement can have an issue but if that problem started before the starter was replaced and it's now repeating, I'd sure include looking at the wiring voltage/connections/relay before replacing the starter again.
Order of operation:
1.Solenoid (blue) slides pinion (silver) to engage flex plate (automatic) or flywheel (manual)
2. Once pinion connected to flex plate gear, solenoid turns on (connects two green pins) starter motor.
Based on the post #1 by mdc9966 starter motor is running but engine is not turning over.
In this scenario typical problem is faulty pinion. It supposed to free wheel in one direction only: to make sure that starter is not destroyed once engine has started but key is not yet released from start position. But it supposed to lock up when you turning over the crank with the starter.
Based on the original post is sounds like it is free wheeling in both directions. Or teeth on the flex plate are damaged. The second one is much rarer occurrence.
Max
Thanks,
If the gear engagement in this starter is actuated by starter solenoid then the issue is within the starter solenoid internally as this wiring is internally in the starter solenoid. If engagement is with inertia of the gear wheel then the problem is with that and again internally with the starter.
So, my question is: does the starter start spinning every time you try to start the car?
If i do not turn off the key, i can hear the starter motor spinning without turning over the engine and this will continue until i turn it off with the ignition switch.
Your problem is internally with the starter motor and as the motor spins it means the issue is with the gear wheel engagement mechanism, likely with the solenoid not moving the gear wheel when you have the problem.
A new starter does not mean it cannot be bad from the beginning, that is why they give warranties for the parts.
