Sponsored by: CARiD
DIY: Joyeauto Wireless CarPlay for NTG4.5/4.7
Rating: Thread Rating: 5 votes, 5.00 average.
Old Nov 21, 2020 | 05:03 PM
  #576
Akim Nubi's Avatar
w207 2015
Originally Posted by SCCoupe
I have installed CUST Version: v2.1.0.9.speach.lt.m4_2
I have the same issue, I can't open CarPlay, AirPlay, Android Auto....
Then I have installed MCU Version: 20.9.28.15, but the problem was not fixed either
I'm asking for an old version to Aliexpress Seller but he hasn't answered me for days
I will keep you informed
EDIT: The problem was solved!
The seller sent me Cust Version: v2.1.0.9.gpe.m4_2
I can use Carplay and Invalid Update is not show in menu.
Thanks for your help!
Need a cop of firmware please [img]blob:https://mbworld.org/e05f02cd-9413-40f4-9bae-3048c6489657[/img][img]blob:https://mbworld.org/dae75c53-03b1-4182-8f45-87f5773122f4[/img]
Old Nov 22, 2020 | 03:20 AM
  #577
Akim Nubi's Avatar
w207 2015
After I installed the software this software killed my unit in this pic below
my unit is road top got it. 2019 no more in contact with the seller I need help please here was my old software
After I updated to new vision now I only get volume and this on sc-screen help
help help
Old Nov 22, 2020 | 02:11 PM
  #578
Akim Nubi's Avatar
w207 2015
Hi, there any chance you could share the download link, please my car is NTG4.7 2014 model I had the same problem as yours many thanks.
Old Nov 22, 2020 | 09:20 PM
  #579
Badwolf's Avatar
2015 E250 4Matic
help help
There are two different hw version on your pics, Benz and benz2, which one do you have?
Old Nov 24, 2020 | 10:01 AM
  #580
Akim Nubi's Avatar
w207 2015
I have the one with this pic Benz
Old Nov 24, 2020 | 02:47 PM
  #581
Badwolf's Avatar
2015 E250 4Matic
yehh, sorry that screenshot from your monitor looks like it might be mine, Hardware version is diffarent, I have BENZ2, you have BENZ, likly find some one that has h/w BENZ maybe their version would work for you, I would contact Roadtop, I can pm you their whatsapp
Old Dec 3, 2020 | 07:20 AM
  #582
Werie's Avatar
GLC43 AMG Coupé
Hi,
Can someone give me the MCU update instruction?
I see that Joyeauto fixed the front 360 camera problem that i also have in my car so i want to fix that with the new MCU update.
Thnx in advance..
Old Dec 9, 2020 | 10:44 AM
  #583
Tvremote's Avatar
mercedes A class FL 13
anyone on NTG 4.5 having an issue where the control knob is actually communicating with the OEM NTG4.5 software in the background?
there are times i can hear navigations from the original system when i obviously haven't selected it from the CarPlay system.
Old Dec 21, 2020 | 03:07 AM
  #584
coroneta's Avatar
w204 coupe
Have files for this version from road top of you want to try
Hi friend i have Benz2 road top unit like you, have a newer cust an mcu update to share?
I have this version and having problems between oem bluetooth and BT´s carplay....i have to disconect the BT car to hear incoming calls or select it into the phone screen always someone call to me.
Before this i had a road top box with HW BENZ and dont have this problem but i bricked it trying to update MCU with a wrong file of a BENZ2 unit.
Old Dec 21, 2020 | 07:05 AM
  #585
coroneta's Avatar
w204 coupe
The seller send to me the cust v2.1.1.2.ltm4_2 for road top HW BENZ2
https://en.mail.qq.com/cgi-bin/ftnEx...&code=1e976048
Old Dec 21, 2020 | 08:32 AM
  #586
Badwolf's Avatar
2015 E250 4Matic
that’s the latest file I have, didn’t update it yet as my car was away for the last 2 months, 17k front end repair
Old Jan 20, 2021 | 03:41 PM
  #587
Ian Molyneux's Avatar
W204 2012
I have this version if anyone wants it for the Roadtop unit.
Old Jan 20, 2021 | 04:00 PM
  #588
inittab's Avatar
none
I want to switch from Joyeauto to RoadTop. What issues are you currently having it any?
Does your phone connect wirelessly every time with out issue even if you leave the car and return a few minutes later? What about the wired connection?
Old Jan 20, 2021 | 06:48 PM
  #589
W204 2012
Yes my phone does connect every time. When I leave the car with the engine running and then come back to the car it does reconnect but it can take 40-50 seconds for it to reconnect. Only updated it today so not had chance to see what issue I have or more to the point what issues have been sorted with this update.
The issues Iv'e had before the update are.
  • Since IOS 14 update it had started to crash every now and then. But I'm told the update will sort this.
  • Echoing on the phone. Also supposed to be sorted.
  • Left steering wheel controls moving the Carplay when I'm changing something on the dash.
  • Not showing the correct daytime or night time screens. I'm told this was also sorted with the update. Yet to test.
  • When reading texts volume a lot lower that music level. This is now sorted.
Overall I think the system is very good. The only gripe I really have is not being able to use the vehicle radio as well as using the Carplay system. If you have the vehicle radio on then you get no sound from the Roadtop unit but I guess all these system are the same with this. I have noticed that since the update if I put BBC sounds on it reconnects and plays every time I get in the car which is as good as it going to get I guess.
Old Jan 20, 2021 | 08:50 PM
  #590
inittab's Avatar
none
Thanks for that input. Very useful. Just trying to avoid moving from one set of problems to another. For my needs, 40-50 seconds to reconnect is unacceptable. It happens with the joyeauto unit as well. I very often am rushing and I need carplay navigation to work instantly.
If it works instantly with the wired lightning cable, I’d be good with that.
Given the limitations I think I need to be looking at something else. I was looking at 10 or 12 inch android screens but I’m seeing folks having issues with those as well.
Right now, I’m using my phone and a vent mount.
Old Jan 21, 2021 | 12:47 PM
  #591
coroneta's Avatar
w204 coupe
Be carefull there are 2 HW versions of road top BENZ and BENZ2 , if you crossflash between them can brick the unit.
Now i have a BENZ2 unit but i bricked my old BENZ unit flashing a wrong mcu version from a BENZ2 unit.
Old Jan 22, 2021 | 05:37 PM
  #592
mbdem's Avatar
GL 350 Bluetec 2014
Hello,
I had an issue on my GL X166 with left steering wheel buttons affecting RoadTop CarPlay, so I installed MCU-BENZ-20.5.25 mentioned in this thread and it did fix the issue. On the other hand, my rear camera stopped working when in CarPlay. Does anyone have any other MCU update for HW Version: BENZ?
Old Jan 23, 2021 | 06:43 AM
  #593
W204 2012
Originally Posted by mbdem
Hello,
I was on to Roadtop customer services through WhatsApp only 3 days ago and was given 20.4.22.16 as the latest version for the Benz hardware. Is the one you have a later firmware? My left steering wheel buttons still affects the Carplay unit.
Old Jan 23, 2021 | 10:36 AM
  #594
mbdem's Avatar
GL 350 Bluetec 2014
I used one mentioned here https://mbworld.org/forums/e-class-w...ml#post8106241
Could you please share the 20.4.22.16?
Old Jan 23, 2021 | 11:40 AM
  #595
W204 2012
Sorry don't seam to be able to upload it. It is 95mb is this too big to put on this thread?
Old Jan 23, 2021 | 11:57 AM
  #596
W204 2012
Hopefully this link is allowed. Roadtop 20.4.22.16 for Benz
Old Jan 26, 2021 | 03:47 AM
  #597
Markorios's Avatar
W204 c250
Carsara carplay w204
hello i have the same one but the seller doesn't send me installation guide and i try several time to reach to him so any one have the same module can help me and send the instructions guide also the frimwear update from where can i get it
2- any idea where i can mount the box
My email: markoriosabdelmesih@gmail.com
Any help please
Thanks in adance
Old Jan 28, 2021 | 12:28 PM
  #598
coroneta's Avatar
w204 coupe
Hi i have Road Top BENZ2 hw version
Last firm i have installed is
MCU Version: 20.10.5.10
Someone has a newer firm to share?
The seller send to me cust v2.1.1.2.ltm4_2 and it has a better sound ( loud and clear ) but i get ramdon reboots of comand system all time.
Old Jan 29, 2021 | 03:02 PM
  #599
Badwolf's Avatar
2015 E250 4Matic
Can you share both files? Have road top hw version 2 and the sound being too low is annoying even at max it's not even close
Someone has a newer firm to share with us?
Old Jan 29, 2021 | 03:19 PM
  #600
coroneta's Avatar
w204 coupe
Here are the links for ROADTOP HW BENZ2
https://mega.nz/file/aNNQVR7C#oGJzZm...vFxOuT3cKACg1k
https://mega.nz/file/zUdQxDgD#DOIzrO...sE8H7HHrjp9Pys
For cust v2.1.1.2.ltm4_2 i dont have the file because the link sent to me the seller has expired and i didnt save the file.
You can also ask to the seller if there are newer files for cust and mcu if you tell him you are having problems with sound and later share it with us ,
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
