Sponsored by: CARiD
DIY: Joyeauto Wireless CarPlay for NTG4.5/4.7
Rating: Thread Rating: 5 votes, 5.00 average.
Old Apr 15, 2023 | 04:44 AM
  #751
S550e's Avatar
W222 S550e, C207 E550, W212 E350
Originally Posted by An123
Oh right, I get you. It's just the iPhone connected to the comand unit? Do you know if I can have the same behaviour with Android auto?
Not sure with Android Auto. I only have Apple phones. I’ve never tested it.
To clarify, when I went into Bluetooth settings, it said MBbluetooth - Connected as well as CarPlay box - Connected. Not sure how I did this but it just worked. I never hit ‘forget device’ on mbbluetooth so I guess both just worked and stays connected. I can choose between AUX (actual CarPlay source) or any other audio source of my choice. Everything still works. Hope this helps
Old Apr 15, 2023 | 05:48 PM
  #752
An123's Avatar
W204 Facelift
Yeah that makes sense 100%, will just need to try it out myself to see if I can get the same behaviour on my Android phone
Old Apr 18, 2023 | 11:27 PM
  #753
S550e's Avatar
Hi all,
I decided to pull the trigger on the new model that I talked about a few posts ago. I got a $10 coupon as well so my total shipped + taxes was $207. Ironically it is going into my C 207. I will report back after install and a few months of use. This will be my second time installing a CarPlay box into a Mercedes NTG so I am more confident this time. I have learned so much from these threads and groups.
Old Apr 19, 2023 | 10:34 AM
  #754
such01's Avatar
E350CDI Blue efficiency
Hi, it seems that you guys are more adventurous than my UK counterparts when it comes to upgrading COMMAND to android/carplay.
I recently upgraded my NTG4.5 unit to one of these:
https://www.iceboxauto.com/mercedes-...outube-netflix
I originally did have the HK system but replaced all speakers with Morels, which sound much clearer and more dynamic. The install went well, the hardest part was getting the command unit back in with all the new wiring behind.
The issue I have is the sound quality from the android unit, whether in app or carplay is very poor,
The bass is very distorted and the sound lacks clarity. There is such a contrast between the sound of the original command and this new unit. I have tried all the settings - from the AUX in command to those in the android system but cannot get anything I'[m happy with.
Has anyone experienced this and if so is there a solution? I'm minded to return this unit otherwise?
Thanks for your help.
Old Apr 19, 2023 | 10:37 AM
  #755
S550e's Avatar
Hi,
It is hard to say what is really causing the problem. Since I assume you installed the screen and the speakers at the same time. But many people have report little to no issues with the Android screens so I am guess it could be a speaker problem. Maybe something with the setup of the amp and EQ? Not well versed in this area but I’m sure someone can help. Could possibly be a bad unit. Contact the seller for help as well
Old Apr 19, 2023 | 11:43 AM
  #756
such01's Avatar
Originally Posted by S550e
Hi,
Apologies, I should have been clearer - the Morels were installed back in 2018. I have contacted the seller who in turn has contacted the manufacturer. Thanks for your help.
Old Apr 22, 2023 | 12:49 PM
  #757
such01's Avatar
I changed some settings on my Iphone and disabled all eq sound settings - this has improved the sound quality significantly when playing via carplay.
I'm not impressed with the quality of sound when using the android & Carplay phone functions. it's nowhere near as good as the OEM system.
Old Apr 27, 2023 | 03:40 AM
  #758
Barooon's Avatar
w166
Had no audio - my fix
GND cables
Hi,
I had no audio on my comand 4.5 (W166, ML350) and tried everything written online to get it working with no success.
i had no fiber optic cable to change to the new harness so I thought my vehicle mit not be compatible. The fix for me was to connect the two GND cables, now sound works.
i am not happy with the sound quality yet, will have to play with the settings.
EDIT: sound quality improved by deactivating loudness in settings, and maximizing volume and music volume.
Old Apr 27, 2023 | 01:34 PM
  #759
such01's Avatar
Has anyone managed to get rid of background noise when making calls? I installed an external mic but the call quality on the receiving end is still nowhere near as clear as factory calls.
Old Apr 27, 2023 | 01:54 PM
  #760
cadetdrivr's Avatar
2014 GL350
Yes.
Continue to use the MB Bluetooth connection for phone calls. After the first few times you manually select MB Bluetooth on the iPhone screen when you make a call it will (mostly) remember your preference.
Use the steering wheel buttons to answer/hang up and it will also automatically switch between the AUX port.
Old Apr 27, 2023 | 02:09 PM
  #761
such01's Avatar
Originally Posted by cadetdrivr
Yes.
Thanks - I was thinking of resorting to using the MB Bluetooth but wasn't sure if the phone can be connected to MB and Android at the same time.
I'll have to test this out tmrw and see how it works for receiving calls if both are connected at the same time.
Old Apr 28, 2023 | 12:42 PM
  #762
An123's Avatar
W204 Facelift
Interested to hear your findings for android
Old Apr 28, 2023 | 08:09 PM
  #763
Brayanjbc02's Avatar
2014, C300 4 matic
Unhappy Head unit
IDK if anyone is active in this anymore but I am having trouble installing the head unit because of the cables the cables that connects to the original is too big and i cant put the head unit back any help plz
Old May 2, 2023 | 04:36 PM
  #764
such01's Avatar
I had the same problem, I removed the heater control panel from below the head unit and managed to really press the wires down into the recess there. It took a good bit of fettling and force to get the loom to fit and some pressure on the head unit to sit flush.
I nearly gave up at one point, but it can be done, just will take time.
Old May 2, 2023 | 10:03 PM
  #765
2014, C300 4 matic
Thank you for responding. You're a lifesaver. I removed the AC controls and cable managed the wires, and put the radio back in and what do you know, it went in.
Old May 31, 2023 | 03:36 PM
  #766
Prince.Ali's Avatar
E400 Coupe
Hi all,
Hey are you able to provide any feedback on this yet? Easier to install due to size, etc.? I am thinking to pull the trigger on ordering this model for my C207.
Old May 31, 2023 | 05:07 PM
  #767
Rv04Nrj's Avatar
E220 CDI coupe
Smile Settings for the CarPlay box
Hi, I have a similar system, looks like you need to go through the CarPlay box settings and set up its own audio settings… likely to be the issue… good luck
Old Jul 9, 2023 | 05:58 PM
  #768
Sea63s's Avatar
C63s AMG
Hey guys,
I just installed roadtop Apple CarPlay on my w204, install went well overall but I noticed that the backrest adjustment button triggers Siri/temporarily pauses music. Wondering if anyone has noticed or experienced this?
Old Jul 11, 2023 | 01:55 AM
  #769
Sea63s's Avatar
C63s AMG
Quick update on this, reached out to RoadTop and within minutes they responded with a new MCU version. Loaded it into the CarPlay box, which worked great, now the backrest adjustment button stopped interfering with Apple CarPlay.
Old Aug 2, 2023 | 06:10 AM
  #770
An123's Avatar
W204 Facelift
Hey, where exactly did you fit the roadtop box, I'm trying to see if there's any options other than taking the glovebox out
Old Aug 2, 2023 | 09:21 AM
  #771
JettaRed's Avatar
Veteran: Army
I did not remove the glovebox, but I did knock out a hole in the inside to allow me to run the cables from the adapter in the back of the head unit to the CarPlay module in the glovebox. Otherwise, it gets kinda tight trying to squeeze everything behind the HU. It also makes it much easier to access the controller if needed.
Old Aug 14, 2023 | 07:40 AM
  #772
volochaev's Avatar
C204 C350 4matic
Question
Hi all,
Has anyone tried this module? I recently found it, and for cars with optional H/K or B&O it may fix problems with sound quality (since it simulates TV receiver). The only thing is that it costs much more than the roadtop box.
Old Aug 14, 2023 | 09:04 AM
  #773
JettaRed's Avatar
Veteran: Army
Originally Posted by volochaev
Hi all,
I've had no problems with sound quality with my RoadTop unit. You just need to make sure it is properly grounded.
I also don't use over-the-air radio (i.e., AM, FM, Satellite, etc.). I use iHeartRadio, iTunes, etc. through my phone when I listen to music.
Old Aug 14, 2023 | 09:34 AM
  #774
cadetdrivr's Avatar
2014 GL350
Hi all,
That unit certainly has a different wiring diagram and it appears to eliminate the need to wire to the AUX port. Very interesting.
Old Aug 14, 2023 | 09:41 AM
  #775
volochaev's Avatar
C204 C350 4matic
I now have a RoadTop module (and previously had Joyeauto) but it still seems that the sound quality is lower than via the Bluetooth connection to the Comand. I've removed the "Loudness" setting in the preferences, adjusted some EQ parameters and the overall volume.
So the iPhone sends a digital signal to the CarPlay module, then it is converted to analogue and sent to the Comand via Aux, then the Comand converts the analogue to digital and sends it via fibre optic to the Harman/Kardon amplifier (or processes it internally). Surely there are negative effects somewhere in there
although the subject of sound is purely individual
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
