DIY: Joyeauto Wireless CarPlay for NTG4.5/4.7
#776
Roadtop Bluetooth audio
Hello I have trouble with wifi connection and only solution to it is software update from what I've heard. I asked roadtop for one and when updated I now have new interesting settings but mainly instead of "use car's bt phone" there is "use car's bt channel" which is exactly what it says, it ditches routing audio thru android auto and lets you stream audio to car's Bluetooth. So no more routing damn aux cable for new installs and mainly high audio quality lol. I was not able to test wireless because problem I am facing right now but it worked on wired android auto.Mind you, my car is w212 with ntg 4.5 and flash this at your own risk. M42R173:https://drive.google.com/file/d/15bS...=sharingUpdate instruction:1. Prepare an empty 8GB USB flash drive (or smaller than 8GB) and format to FAT322. UNZIP the file first, copy "ISPBOOOT.BIN" file onto the root directory of the USB drive. You just need the "ISPBOOOT.BIN" file.3. Connect the usb drive to the decoder box.'Setup' ->'Software Update' -> password 8032 -> 'System Update ISPBOOOT.BIN', then the update will start. Wait untill the update is done. After the update, there will be a new setting "Use car's bt channel". Turn it on, connect your phone to the car's bluetooth and audio from carplay will be played through car bluetooth. However, you can't use Airplay with that setting on. You have to turn it off then choose AUX for Airplay. And of course you can still use AUX for carplay as before, just turn the new setting off.
P.s if anyone knows solution to issue in 3rd picture, i'd greatly appreciate it
#777
Dang, wish I saw this before I took all of my trim off and replaced it last week. Would have been nice to do this while the trim was already off.
#778
W212 2011-2015,with NTG4.5/4.7 System carplay box
Simply plug this device into the glove box socket to obtain wired/wireless carplay&Android auto. Needn't to remove the car screen and host
Promotion link:https://carlinkitlife.com/wireless-carplay-android-auto-for-mercedes-ntg4-5....
If you have any interest in our products, you are welcome to take an $20 discount code"SAVE20" for your action.
#779
Hi. I have a 2012 W212 and just installed the RoadTop for NTG 4.5 and 7 inch screen. Everything seems to be working as it should except I am getting a crackling noise out of my passenger front speaker. I hear the music but its crackling / staticky, especially as I increase the volume. I checked the grounds and tried the two options of connecting the Audid Gnd to the Gnd of the Video harness and also the Audio Gnd to the car metal. I still get the crackling noise. Does anyone have any suggestions that they can think of? It is very frustrating. When I play audio through any other source, the speaker works perfectly.
Any help is greatly appreciated.
#780
#782
#785
2023 EQB 350 & 2014 GL350
Also, it depends where you live geographically and the options on the car.
A unit like that is EXTREMELY easy to install, but we did not receive many head units with that port in the USA, for example. And in other markets it depended on the option package(s) installed.
Check your glovebox before ordering.
#786
#787
Hi and thanks for the reply. I have tried, but I think my Command AUX input is the root of the problem. My car has the MMI connector in the centre armrest, rather than the standard 3.5mm AUX jack.
I’ve been supplied an adapter, MMI to 3.5mm, but my head unit doesn’t see anything and just gives a ‘media interface unavailable’ message. It has always given this same message, regardless of whether the adapter is plugged in or not. I’ve tried with different sound inputs just to check (iPod, phone etc) but still nothing. Thank again for the advice 👍🏻
