Got a deal for e very cheap W212 with high mileage
The car has been used before as a Taxi in Germany, but it looks very clean in interior and exterior. I was thinking of investing some more into it like changing color, adding the e63 w212 body kit, etc. What do you guys think, can I expect it to last for another 100,000 KM / 60,000 Miles?
Even if you are a handy DIYer, It takes only one significant problem to run up a big bill... just for parts. Just updating the looks with new grille, etc, will double what you paid for the car, and it still will be worth only what you paid for it initially, or less.
A TAXI drives every day and logs in miles very fast. They easily drive 100000 km/year so this car most likely has the actual km reading north of 500000. You can check for this by reading the car's engine or transmission module where the actual km for that module is stored. If this is a dealer selling it then you need to find another dealer to read the km and tell you the truth.
But, regardless of the km reading if it is a Diesel the engine will not go out or very likely will not go out. The most wear and tear is with the suspension so the shocks and different bushings wear out and some of these have probably been changed already.
I would just buy the car and drive it as it sits as long as it drives. Heck, with 4000 Euros you can't even buy a moped anymore.
When actual kilometrage can be in question, you are buying older car for its condition, not the paper records.
Was the car properly maintained or driven close to the point when wheels are failing off?
I'd do compression test and if that shows good, we are talking 1 million miles, or 2 million kilometers engine.
Beside color, they also have different instrument cluster to incorporate the meter, while cabbies don't care much about gadgets, so don't expect too many options on the car.
Wrap is the way to sell the old taxi with the pristine color under the wrap when removed. With this and wound odometer it is much easier to sell as a used car.
Experienced German used car buyers know all this and inspect the roof paint very closely as the suction cup TAXI sign mount sometimes leaves a very faint round marking on that paint under the wrap and, of course, they check the actual mileage of the engine and/or transmission modules.
But you can make a trip to Germany and see for yourself as you don't believe anything I say.
I do do agree with others though that question doing that much work on an old diesel with that many kilometers.
-Shock absorbers at 750,000km
-Wheel bearings at 800,000km
-Alternator has been changed 4 times
The driver emphasized in the article that the engine has not been opened and he plans to drive the car at least until next spring when it will have about 1,200,000 km. He said the high milage only shows in the number of rock chips! He said even the original seats are holding up great. The car has been driven in two shifts since new.
But anyway, that sample brings again possibility of odometer rollback. So do the proper checks.
To the OP - 4k Euros seems like a steal, IF there's nothing wrong with it. Get a pre-purchase inspection performed if you can, or, just go into it expecting to spend another several thousand Euros on the car. And if you end up not having to, then great!
Those diesels last a long time. I wouldn't waste money modifying it though. Maybe just change the color.
