Sponsored by: CARiD
E350 2010 with gas pool on back seat
Old Nov 15, 2019 | 08:59 PM
axilleas63's Avatar
E350 2010
Do you guys know that since 2014 there in ongoing investigation on gas leak on back seat of our cars and Mercedes Benz refuses to take any action. I just took my E350 for service and I was told that my car was leaking gas , the mechanic lift my back seat open the two hups and there you are gas was under my back seat ready to light up. What **** me off is that ****en Mercedes knows about it they have not done nothing about it . watch the video below if you don't believe me.
https://www.wsbtv.com/news/local/mer...seat/138171583
Old Nov 15, 2019 | 11:03 PM
cetialpha5's Avatar
It was a well known problem for the W211 which was 2003-2009. They eventually offered an extended warranty for 15 years unlimited miles. But that doesn't extend to the W212. I'd say keep your receipt and if they ever decide to offer an extended warranty, they will reimburse you for the repair if you had to pay for it out of pocket. Or you could try call MB corporate and ask for goodwill and mention how they have the same problem on the W211 which was covered.
Old Nov 15, 2019 | 11:25 PM
pamiboy's Avatar
E 350
Mods, please move this thread to the correct section so that this thread doesn't get lost for those who need to see it.
Old Nov 16, 2019 | 08:32 AM
DFWdude's Avatar
2016 E350 Sport
This is not good, not good at all. I will have to inspect my car...
Thinking further on this... I'd like to determine whether the OP is regarding a continuing(?)or expanded investigation (in 2014) of remaining W211s. My W212 wasn't manufactured for another 18 months. Not good to read about in either case...
I do not smell gas within my car.
Old Nov 16, 2019 | 09:08 AM
RA72825's Avatar
^ he said he has a 2010, so W212
Old Nov 16, 2019 | 12:15 PM
cetialpha5's Avatar
It's only noticeable when you fill up the tank. Before it was covered and people were told that you need to replace the gas tank to fix it, they were quoted 3-4k for the job. So some people just resorted to not filling up the tank. Some people who were out of warranty fixed it by just using some RTV sealant on the tank. MB just likes to replace the entire tank including fuel pump when the problem occurs.
Old Nov 16, 2019 | 12:42 PM
DFWdude's Avatar
2016 E350 Sport
There is no plausible excuse for exposed fuel anywhere in the passenger compartment. Zero, Zip, Nada. Some of you clowns puff on cancer sticks for god's sake!
This is (almost) enough to convince me my next car should not be a Mercedes.
Old Nov 16, 2019 | 01:18 PM
cetialpha5's Avatar
Like many auto makers, Mercedes gets parts from multiple supplier, possibly Continental which makes parts for many other car makers. It's not exclusive to MB. Also to the OP, I'd file a case with the NHTSA. You can do it online. I actually did that once on a Ford and a recall happened a bit later. Not to say that I caused it, but it was a problem that many had encountered and if enough people submit a complaint, something might happen. In that case, they actually contacted me and they even sent me a fedex tag to send them the defective part which I sent to them.
https://www.carcomplaints.com/news/2...gas-tank.shtml
https://www.usatoday.com/story/money...aks/459857001/
https://www.import-car.com/pinpointi...nz-fuel-leaks/
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Old Nov 17, 2019 | 08:50 PM
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
OP. You are cover under PZEV Emission warranty from MBusa for 15 year or 150k miles.
The gas leak under the rear seat is most likely a fuel cap leak and the PZEV will cover that.
First, take it to a certified Mercedes dealer and ask the service advisor during write up if your car is under PZEV which will indicate when they run your VIN, if PZEV is indicated, most likely the dealer will ask you to pay for 1 hour diagnostic fee at which time they will find this cover under the PZEV emission warranty, then they will fix the problem and waive the diagnostic fee.
I would recommend indicating the car is slow to start at low speed and hesitates during acceleration. They will check for fault code and if your exhaust manifold is bad, the manifold will be replaced as well under the PZEV warranty.
https://assets.mbusa.com/vcm/CAC_RAP...ndwarranty.pdf
Good luck.
Old Nov 17, 2019 | 10:29 PM
cetialpha5's Avatar
My guess is that the OP doesn't have a Pzev car. It wasn't very common and only a small percentage of cars out there are Pzev. But if it is, it'd be covered. Normally the dealer would tell you it was covered if it wasn't but lots of Pzev owners were told it wasn't covered by the dealer and then had to take it up with corporate before being covered when they should have been told that in the first place.
Old Nov 18, 2019 | 12:02 PM
S63AMG888's Avatar
I can’t speak for other states, but here in California. You would be cover especially with the issue the OP stated.
FYI. I see allot of Mercedes that has this PZEV warranty that was covered.
obviously the OP is not going to drive around with a pull of gas in under his backseat so I would recommend taking it into a Mercedes dealer and let them run coverage because this is a known issue and it limited to 1 or 2 cases. Pay the 1 hour diagnostic fee as you will be getting it back from the dealer once it is confirmed coverage under the emissions warranty.
Best of luck.
Old Nov 18, 2019 | 10:08 PM
C280 Sport's Avatar
MB’s of all kinds.
I never knew this was an issue. No gas smell on my 2012 E350.
