Oil Dip Stick Keeps Popping Up
2012 & 2014 E350 Sports, 2017 E43
My 2012 E350's oil dipstick keeps popping up, first, it was doing every couple of weeks, now it has become almost every few days. Back in August of this year when my CPO was expiring, the dealership said they replaced the motor and transmission mounts, and they said it should take care of the problem. The problem is still there and has become more frequent in the last few weeks. Anyone experienced, the same problem with their W212? Mine only has little for 52K miles. I am no longer under warranty, any ideas where should I begin troubleshooting this problem? Thanks
Ray
Ray
AllPhonesAretap (09-11-2022)
Excessive crankcase pressure can cause the dipstick to pop out. Let’s hope it’s just in need of a new O-ring on the dipstick
Received 1,747 Likes
1922 Ford Model T / no OBD
Clean crankcase ventilation pipes.
Than you can always make easy blowby test
On stopped engine, remove oil fill cap and put a napkin over it. Start the engine and observe if the napkin stays.
When napkin gets blown away, put a cardboard on the hole and observe if it stays.
When cardboard gets blown away, start looking of new car.
Aussie_E350_Wag (06-20-2023)
I'm used to see car engines to have crank case vent tubes connected directly to the engine intake that should take care of any pressure caused by piston ring blow-by that even new engines can have. Don't these MB engines have this?
Ray
Ray
I never knew this cold happen, how do I check if anything is clogged? I will try the cardboard test and see if I need a new car lol 😂
At least not for last 50 years. Even W123 diesel had complicated drainage system that would separate the oil and dump it back to the pan.
I am surprised that I am the only one with the problem. It does not look like the O-ring on the dip can be changed. I will start with a new OEM dipstick. Does anybody have a part number for 2012 w212 oil dipstick? Thanks.
Did you read the replies at all?
New dipstick can cover the results, while it will not do anything for the issue.
Yes, I did. I was going by the fact that the O-ring on my dip stick looks very stiff and brittle. I can do the napkin / cardboard test before, I order the dipstick. Looks like local dealer wants $67.50 plus tax. Thanks
That's good, you should have a very slight vacuum. Given that, you don't need to clean the PCV hoses.
If the o-rings on the dipstick have shrunk due to age, I could see the dipstick working itself out over time from vibrations. I want to say mine works itself up a few mm over time too so mine probably needs attention as well. One could probably just source new o-rings instead of buying a whole new dipstick. If you were feeling like a champion, you could pull an o-ring off your new dipstick and measure the diameter as well as how thick it is and post it here for posterity
Received 1,755 Likes
2016 E350 Sport
As suggested I would replace the o-ring first. This will be a metric o-ring, and you can find it here... https://www.applerubber.com/src/pdf/...ze-o-rings.pdf
If you have a Harbor Freight nearby, or an Ace Hardware, you can buy single o-rings, or sets for little money. I'd be tempted to measure the old o-ring or take it with you to the store, and try a slightly larger one (metric or Imperial), to see if it seats more securely. For the price of an o-ring (10-15¢) you can experiment. It would be silly to buy a new dipstick just to solve an o-ring problem.
I buy o-rings all the time for my Air Rifles that work on compressed air. Here in Dallas I buy from H&D Distributors (214) 351-1251. They ship all around the country... http://www.hddistributors.com/ Or you can shop the o-ring store... https://www.theoringstore.com/
MBNUT1 (01-15-2020)
An easy way to see if that is the case would be to lower oil level as it should be very safe to operate with level at half way between low and high.
Another way would actually be to remove the O-ring so the pressure can get out without popping the stick out.
Then, of course, if the O-ring can be changed an O-ring could be used that is so tight the small air pressure in the tube cannot pop it out.
I'm saying this as the crank case should be under small vacuum when the engine runs and there should be no force to press the dip stick up from its place and the only place such force could build-up is the dip stick tube itself if the bottom end of it is sealed, what a high oil level would do.
I just changed the dipstick, and the problem went away. The o-ring, on my OEM dipstick was pretty stiff plastic and I would have Dremel it out. I got a febi dip stick and it has softer rubber type o-ring. Thanks for your input.
Not that I have this problem but all the recommendations and comments were outstanding. This is the reason we are members of the site. A lot of experienced and smart people out there.
I think new oring, holding the dipstick firmer covered the symptoms, not the issue.
How the blowby test shows vacuum and driving blows the dipstick up?
2016 E350 Sport
When most o-rings get exposed to other petroleum products, they will "entrain" (absorb) some of the oil through pores in the surface of the oring, or most typically through the spot where the o-ring is cut from the casting sprue during manufacture. Especially true with Buna rubber o-rings.
This makes the o-ring swell, which may be the reason the dipstick rises in the tube... The rubber swells and pushes the stick up. But if contained within the dipstick tube, the oring will just get brittle over time. In short, it may seem like stiff plastic, but it isn't. It's a type of synthetic rubber, just like mine is. Try to pick it out of its place on the old stick with an ice pick, and it should break into several pieces without much prying.
This is a good reminder for all of us, though, to use a rag to clean any oil from the dipstick o-ring before each reinsertion in the tube. Just a swipe is enough.
I hope you didn't spend a lot of money on that new dipstick. I can all but guarantee you don't need it.
So, my dipstick made its way up 3-4 inches again. I’m not sure what is causing this, the o-ring seems fine because the dipstick stays fairly snug. I don’t think it’s the pressure that pushes the dipstick up that high, that’s a lot of pressure? I mean once I pop the dipstick out, there’s quite a bit of friction to pull the dipstick up another 2-3 inches. It seems like the dipstick somehow wiggles itself up, from vibrations?
Any thoughts?
Any thoughts?
I am experiencing this phenomenon recently too. My dipstick o-ring is hard and unusually flat on the contact surface. I suspect that a new dipstick o-ring is more round.
Here is the part number for M276 engine dipstick 276-010-18-72
2016 E350 Sport
I changed the oil on mine last week. I use the extractor method (through the dipstick tube). The dipstick was fully seated in the tube before I pulled it out, exactly where it was when inserted more than a year ago.
As for rising 3-4 inches, I'm not convinced there is that much clearance under my hood.
I'm an older car guy and I agree with the posts about high crankcase pressure. If the emissions system is clogged with by a faulty PCV valve or even an EGR valve then the fix is not bad. If I recall, direct crankcase vent tubes ceased to exist when PCV valves were introduced to reduce pollution ....so forget that line of thinking. I doubt it is a dipstick problem.
As was stated by other posters you may be getting to much blow by , which means piston rings.
Sorry for your problems.
Ray
Ray
