Fob stops working intermittently
I've already tried replacing the battery (wasn't getting a low battery notification). This behavior happens very randomly and only once in a while: it could go months and never happen, it could happen multiple times in a day. I've never had a problem starting the car except when I leave the fob in the ignition for more than a minute or two, though taking it back out and trying again always works. I don't have a second remote to test with.
Anyone run into this sort of thing, or have any ideas on things to check? I'm due for a trip to the dealership at some point, so if I don't find a solution, this will get added to the checklist.
Have you attempted to change the fob battery?
Yes, I changed the battery on the fob already. I figured the battery was causing the glitchy behavior, but it's happened a few times since.
I know that a key is not cheap, but it beats ruining a vacation. Shop around with dealers in your area for a new key. They need to be ordered directly by your dealer and there is no short cut.
I just called around and one dealer near me gave me a price of $360. The other dealer nearby wanted that plus $200 labor
$360 is about what I paid for a new key for my '04 Volvo, so fortunately that sticker shock isn't anything new.
As for only having one key, add it to a bunch of other keys and put one of those Tile key finders on it. Also if you call around to a bunch of dealers in your area, you could find a lower price and then you could call your local dealer and tell them that a further dealer has it at a lower price and see if they will price match. Sometimes they also have service coupons you can use.
I think at this point I need a second key anyway, so I'll do that and see if the behavior persists.
Thanks for the input everyone! I'll post updates as I get them.
I have a spare key inside my dash that works with the Mid-City Engineering remote starter. When the weather got cold last fall the remote start wasn't working. Found that little prong on the spare key wasn't making contact anymore. Bent it out a little and all was well.
https://mbworld.org/forums/e-class-w...ml#post7970727
I had just about convinced myself to dig the EIS out and fix the (assumed) issue with the solder joints inside... Then I replaced the battery in my (only) key, and was left dead in the driveway.
Since getting a new key, I haven't had any issue starting, so likely no EIS issue (will see when the weather turns hot again, that issue seems to manifest when the under-dash area is warmed up and humid).
For me, after all this, I still have only one known-good key, the New one.
Good you have one on the way, OP!
