2014 E350 oil filter for DIY
Does anyone have a recommendation of the best Oil filter I can use if I decide to do the oil change myself.. I bought an Oil extractor so I can suck the old oil out. I plan on doing all the oil changes myself now that the warranty is up. I also bought a power bleeder for draining the brakes. I plan on keeping myself busy over the summer. I am also looking at buying a power lift so I do not have to jack the car up. If anyone has suggestions on that I would also be interested. Thanks
You are good with any of the top brands (Mann, Mahle, etc.). Go to Rockauto and buy several. Since you are going to get a lift you might consider getting transmission filter, gasket and bolts, air filter cabin filter, brake fluid, transmission fluid, etc. Remember spark plugs are due at 60k too. Saves on shipping costs.
I have a Quicklift which raises the entire car about 18-20 inches, more than enough room to use transmission fluid change, great for brakes, suspension and tire rotation. 5000lb capacity, I use it for all our vehicles. Plus it can be stored when not in use.
Mahle is the filter you want. Superior to the Mann or Hengst or others. If you compare them it will be obvious. Even more obvious when changing out after 10K miles. Mahle is what the dealer uses and what came stock from the factory.
I did all the work on my c230k for 15+ years. I've had the Pela oil extractor for most of those 15 years and it still works great. Also have the Motive power bleeder. I do not put brake fluid in the Motive when changing brake fluid, I just keep topping off the brake fluid reservoir. It's a pain, but I use it for multiple cars and don't want to cross contaminate different brake fluids. I would soooooooo love to have a lift. I'm jealous!!!!!!!
I use genuine Mercedes filter from FCPEuro. One time ~$22, lifetime warranty. I’ve changed my oil 3 times already and the last two times costed me practically nothing (cost of return shipping if used parts). Every 10k miles I change the oil, oil filter, engine air filter, cabin air filter, and wiper blades. All Mercedes parts, for only the cost of return shipping. Costs me about $50 for shipping everything back. So every service of all the above costs me $50. Cheap overkill maintenance
NuMBS500er (05-12-2020)
I don’t know how it’s sustainable for them business-wise but they’ve been doing this over 10 years now? Guessing they are betting on people not taking advantage of it as much, due to hassle of shipping old parts back? Either that or that most people don’t keep their cars as long.
Yes, you should check them out. They have lifetime warranty on everything, including wear and tear items like wiper blades, filters, even used oil! Brake pad and rotors. Best thing is that it’s not brand specific. So I buy OEM brand if they have it. You just have to send back the old parts. There isn’t a catch and I feel like I am robbing them
You’re welcome! I was a skeptic at first too, but 6 years buying parts from them, not a single issue. Wish they had parts for my Lexus too
Received 1,499 Likes
There's lots of cheap lifts from China, they seem to be in the 2-4k range.
I've done the tranny fluid/filter change on all the family cars for years. It's not really that bad, albeit a bit messy. Simple tranny fluid change is no worse that an oil change.
