Sponsored by: CARiD
Bad engine/motor mounts? 2010 Mercedes E350 4Matic
Old Feb 21, 2020 | 05:12 PM
muj416's Avatar
2010 E350
Does this look like bad engine mounts?
Had the E brake on, in drive with foot on the brake and revving
Car vibrates at a stop when either in D or R
Old Feb 21, 2020 | 09:52 PM
pb39374's Avatar
2010 E350 4Matic sedan
Yes, looks like bad mounts. I just replaced my two mounts and transmission mount on my 2010 e350 with 48,000 miles. I was getting some vibrations as a result of the bad mounts.
Old Feb 22, 2020 | 11:30 AM
OkieBlackBeauty's Avatar
W212 E550
pb39374, if you don't mind my asking, what was the cost to have the motor mounts and transmission mounts replaced?
Old Feb 22, 2020 | 11:37 AM
RA72825's Avatar
They need to be inspected. You can’t tell anything by revving your engine and watching it move. Get under there. They are hydraulic and will be collapsed if worn.
Old Feb 22, 2020 | 12:33 PM
pb39374's Avatar
Mine were all collapsed.
I had it done at the dealer (I had an aftermarket warranty that covered it). Parts were $210 for each of the engine mounts and $187 for the tranny mount. Labor was $1,100. So all in was $1,700.
Old Feb 23, 2020 | 03:39 AM
cetialpha5's Avatar
The tranny mount is really cheap, about $55 and I believe it's Corteco that makes the OEM mount. It's a simple 20 minute job. The two mounts on the other hand are much more complex, there's several threads on how difficult it can be as a DIY project.
Old Feb 23, 2020 | 08:24 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Isn't it also more labor intensive on the 4Matic cars than the RWD ones?
Old Feb 23, 2020 | 02:42 PM
cetialpha5's Avatar
I don't recall that one was simpler than the other. Even complex on the E550. The stuff that's in the way like the exhaust, alternator, etc are the same for both, although one could be slightly easier than the other. Haven't done mine yet, but I'm think it's going to be a few hundred with my indy as it's not going to be a quick job.
Old Feb 24, 2020 | 02:53 AM
leardriver's Avatar
2015 E350
The parts were about $125 and 4 hours labor at my house when I did it, with lots of interruptions. It is not nearly as complicated as the videos make it look.
Old Feb 24, 2020 | 05:07 PM
mellonc's Avatar
E250 Diesel
I replaced mine at 80K miles. According to my advisor, they go bad around 40K to 45K miles for my model. YMMV.
