Car pulling to both sides
Thoughts?
Thanks!
Thoughts?
Thanks!
Ask them what they aligned as the ONLY thing you can adjust is the front toe. There are no slotted bolt hole of any kind in this suspension to change alignment. You need some special after market off-centric bolts to move anything and I understand these can only be used in the rear.
They may have moved the toe and if it is not done correctly you may end up with a car where the toe changes around zero depending on car's ride height. Ride height changes toe and it must be set with the ride height at correct position. I don't know what this is on the car you have (like I have) but I have been present when alignment was done for my previous car and the shop who obviously knew what they were doing pulled the front of the car down with a strap for the proper ride height before they measured anything.
I had a pull to the right from the factory with a cls550 as many Mercedes do and adjusting caster forward on passenger side fixed it along with reducing camber on both sides.
Thoughts?
Thanks!
if you are the original owner than you won’t have the camber/caster “adjustment” bolts.
You should look for a recommended independent shop in your area. Check suspension components.
Have you tried using different settings on ride height if it makes any difference to pulling? You could drive at sports mode and compare to the Comfort with raised position that should stay on at city speeds. On highway the raised position automatically drops off.
