2014 LED Headlight upgrade
I've found these DEPO headlights on USR but they're out of stock unfortunately.
https://www.uniquestyleracings.com/i...product_id=428
Is there an alternative that anyone may know of? I want something plug and play, that I do not have to reprogram. Thanks!
Philips Diamond Vision H7s...
Plus, you don't have to look at those gaudy, overwrought, double eyebrow DRL chevrons of the Full LED package. Proof positive there's a solution for every automotive taste. (Sorry for my opinion, I guess)
You can also replace the halogens with actual LEDs plug-ins if you look around. But I worried about the heat these appear to generate (they have huge heat sink appendages in the back), so I tried these and they have the desired look, instead
https://www.amazon.com/Philips-Diamo...7726712&sr=8-4
Try them, For $23 they will be a very cheap experiment.
I should note that my 2018 MX-5 Miata has adaptive, auto hi/lo beam, bi-LED projectors that perform just as well or better as either W212 option, so the idea that the lighting package is something grand is wrong.
I wanted to go with the LED's as they're usually brighter, but worried about fitment and the light pattern they would produce because of the high beam mirror/housing.
I retrofitted the OEM ILS LED headlights but it's still a work in progress. Right now they are working but I have an error code. I haven't been able to get it fixed because no one will touch it during the stay-at-home orders.
What I can tell you about going full OEM is that if you are looking for the automatic high beam/low beam function, your car needs to be equipped with the "multifunction stereo camera" on the windshield. If your car did not come with factory ILS or distronic, you probably don't have it. If you want to add it, you need to source the camera along with the cable and the windshield designated for it. It gets expensive really quick - even without the windshield replacement, it's quite an expensive project as it is.
Here's a link to the DIY I've been working on: ILS Retrofit Just keep in mind that the project is not complete so I would recommend further research before jumping in.
