Sponsored by: CARiD
E250 Bluetec: Terminate EGR, DPF, and SCR systems
Old Jun 1, 2020 | 07:54 PM
diezmerc8's Avatar
2014 E250 Bluetech
I have a dire need to terminate the EGR, DPF, and SCR systems in my 2014 MB E250 (OM651).
I read all the posts on this thread here: https://mbworld.org/forums/glk-class-x204/697383-finally-got-done-glk250-dpf-scr-deleted-egr-disabled-3.html
I'm hopeful that the kit designed for the GLK 250 will be compatible with my E-Class sedan. It seems like GLK 250 kits (RawTek/Malone or Buzzken/JR) are my best options.
I investigated this last year due to some problems with the DEF system that strangely disappeared with time and following strict DEF top-off routines. At that time I did not see a compatible solution for my vehicle
Today, my fortune is not so good. The crude diagnostics I have available indicate the DPF is clogged and likely one (or more) exhaust sensor malfunctions. The vehicle is currently in limp home mode.
Anyone have any advice on preparations for the modification and the maintenance routines that one should follow after the modification?
I appreciate any information you all have on your experience having completed the modification. But, I do prefer to see a response from a fellow E250 Bluetec owner whocompleted the modification and tune.
File Type: pdf
Old Jun 2, 2020 | 06:37 PM
mellonc's Avatar
E250 Diesel
How many miles do you have on your car?
Old Jun 2, 2020 | 09:04 PM
diezmerc8's Avatar
2014 E250 Bluetech
The car is a MY2014. I purchased new in March 2014. The car has nearly 82k mi.
Old Jun 2, 2020 | 09:05 PM
diezmerc8's Avatar
2014 E250 Bluetech
UPDATE: As anticipated, several shops are totally capable of providing the tune I need. No shops have identified a compatible downpipe with confidence.
Old Jun 2, 2020 | 09:51 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Check with tunemyeuro out of Canada. They've provided the software for a GLK250, 350 (om642) and 320 (om642) for my local shop. If anyone know's what's required, it's them.
Old Jun 3, 2020 | 12:29 AM
mellonc's Avatar
E250 Diesel
eerily similar to my mileage.....(same model and same year).......
Old Jun 3, 2020 | 12:31 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Lot changed in last year since you investigated the issue.
I understand you are in Canada, while EPA in USA hit hard some shops offering emission system delete.
How much the delete is going to cost you?
What also come on the market in last year are DPF for $600 and Nox sensors for less than $100.
Meaning instead of spending more money to become illegal, you might want to consider the proper repair.
Old Jun 4, 2020 | 06:44 AM
diezmerc8's Avatar
2014 E250 Bluetech
Appears I will need a custom downpipe; No prefab turn-key kits for the E250; Seems the E250 has a CAT/DPF combination component; Whereas the GLK's are distinct. Everything after that looks similar.
GLK250 (distinct CAT/DPF)
E250 (DPF/CAT combo)
Old Jun 5, 2020 | 12:16 PM
DaThresh's Avatar
2016 Mercedes E250 Bluetec Designo
Old Jun 5, 2020 | 01:05 PM
kajtek1's Avatar
When those models do suffer from baby teeth in new technology, by now it is well taken care about.
Same engines in Sprinter vans exceeded 600,000 miles still running strong without breaking the law.
Fact is that E250 Bluetec is rare animal in America, so if you don't DIY, you will suffer from lack of qualified service, but once again, technology for repair is easy to find and become affordable (still can't understand why DPF for sedan cost 50% more than for the same engine in Sprinter though)
Side note - my 2014 model has DPF model that can't be find anywhere. Dealer found me a rebuild substitute, but couple years ago they could not supply it.
Now we have new forum sponsor who offers new, aftermarket DPF with all certifications and warranties. He already has DPF for Sprinters and promised DPF for E250 are on their way.
Old Jul 19, 2020 | 10:52 PM
SymsWRX's Avatar
997.2 911 Turbo, E46 M3 Cab, F15 X5 35d
Hi,
​​​​​​I'm considering buying a 2014 e250 bt and have been looking around for vendors that have the full deletes for this car.
Has anyone had any luck with it? Or will I need to go full custom? Worst case my fab guy can do a full custom but I would love if someone like buzzken had a kit for this car.
I'm confused as to why there are so many kits for the ML/GL/GLK/Sprinters but nothing for the E class. I had the same struggles when I was shopping for an E350 bt a few months ago (have since decided to go with an e250 bt over E350 bt).
The great thing is at least Malone tuning is local and those guys can take care of all the tuning needs.
Thanks!
Old Jul 20, 2020 | 06:58 AM
diezmerc8's Avatar
2014 E250 Bluetech
As of this month, no hardware kits available for this vehicle. It seems you know a "fab guy" that can complete the hardware portion. If you need additional information, please send me a PM.
Old Jul 20, 2020 | 02:43 PM
kajtek1's Avatar
I think it was Malone who was forced in CA to send letters to delete buyers offering them free work on bringing the vehicles to stock?
CARB is not buying "for offroad use" tunes anymore and question is when other jurisdictions will follow?
I sense some kind of delete-phobia is still floating around beside Corona 19 ?
At present time there is not a problem to keep the vehicles with legal emissions for low cost.
Old Jul 20, 2020 | 03:24 PM
DaThresh's Avatar
Old Jul 20, 2020 | 04:02 PM
kajtek1's Avatar
It is not pay once, when the law will chase the shop doing illegal tunes and will force you to bring car to stock.
Beside, you MIGHT be sacrificing your lungs in the process.
I highlighted "might" as my car with DPF delete passes NV smog on rolls with 0 particles. I still have DEF working, but keeps scratching my head over it.
Old Jul 20, 2020 | 04:03 PM
DaThresh's Avatar
Old Jul 20, 2020 | 04:06 PM
kajtek1's Avatar
Originally Posted by DaThresh
Not in the land of the free down here in TX! Diesels are exempt from emissions here.
You still can't shoot people on the streets at will?
You better check your laws. Bet you $100 there is a law forbidding tampering with emission systems. Even in TX.
Old Jul 21, 2020 | 09:08 PM
diezmerc8's Avatar
2014 E250 Bluetech
Please guys, the choice is unique to each individuals' circumstances, evaluation of risk, and general beliefs. If the benefits outweigh these costs, you delete and enjoy 10% better fuel mileage, noticeable power output increases, and a more reliable engine. If the risks outweigh the benefits, you follow the mandates on manufacturer's and shops, pay exorbitant repair fees at the DEALERSHIP that only patch these troubleprone and destructive systems. The choice is MINE, Your's, and Your's. Happy Motoring for the Best Value Proposition!
Old Jul 22, 2020 | 12:00 AM
mellonc's Avatar
E250 Diesel
I want to take mine out and keep it somewhere in case I sell the car later. However, I don't think the process is this simple. I wish there was a good shop that'll do it without permanent change but can't find out around this huge La La land.
Old Aug 16, 2020 | 06:41 PM
MarcusV's Avatar
2014 E250
I read all the posts on this thread here: https://mbworld.org/forums/glk-class...isabled-3.html
Do you have any updates on which route you took and how it is working for you?
Old Aug 16, 2020 | 07:02 PM
diezmerc8's Avatar
2014 E250 Bluetech
Exhaust is modified and ECU is tuned. Fuel mileage is improved more than 5%. Slight diesel smell in idle (as expected). Power output (acceleration) is noticably increased. No complaints. Looking forward to much fewer repair hassles and longer ownership.
Old Aug 17, 2020 | 09:17 AM
cadetdrivr's Avatar
2014 GL350
If anybody in the USA is considering this, and is not in a time critical situation, I'd suggest waiting a month to see the results of the MB settlement with the government.
As an example, in the the most recent diesel settlement (Chrysler), diesel owners received approximately $3K in restitution, new ECU software, and an extended warranty (10-year) on all the emissions equipment. (source) One catch: modified systems must be restored to stock to receive the benefits of the settlement.
We don't know (yet) what the MB settlement includes but it may be worth waiting a month to find out.
Old Aug 19, 2020 | 07:38 PM
DaThresh's Avatar
Old Aug 20, 2020 | 08:47 AM
cadetdrivr's Avatar
2014 GL350
Any way to track this development?
I'd say follow the news. There is already an agreement for a settlement so it's a matter of getting everything finalized and signed.
I'm gonna suspect that if it involves cash it won't be a secret for long on this forum.
Old Aug 22, 2020 | 09:23 AM
MarcusV's Avatar
2014 E250
Did you ship your ECU to have turned out get a DIY? Did you find an exhaust kit already made? My counter just started and regen hasn’t helped and I will need to figure something out soon. I have found a lot for every other class, the E class though seems neglected in this area.
