Sponsored by: CARiD
New to me 14 E350 terrible buzzing sound from passenger rear?
Old Jun 4, 2020 | 03:07 PM
tpdtopcop's Avatar
Saab
Well my new to me month old car has a hiccup. While driving home from work there was a terrible buzzing sound, which sounded like from passenger rear inside of car. Maybe speaker? It was like interference maybe? Don't know but loud and irritating.
Old Jun 4, 2020 | 03:40 PM
tpdtopcop's Avatar
Saab
Took the car out for another drive I’m shut the Bluetooth off on my phone and when I press the horn you could hear static through which sounds like the speakers
Old Jun 4, 2020 | 03:42 PM
tpdtopcop's Avatar
Saab
So I am at a loss
Old Jun 4, 2020 | 04:04 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The 14s had an issue where the speakers would sometimes melt causing all sorts of issues, can you pull that speaker out for an inspection?
Search the 212 forum for melting speakers - IIRC it seems basically isolated to the 2014.
Of course it could be something simple like grounding. Either way you’re going to need to pull the door panel to check.
Old Jun 4, 2020 | 04:06 PM
tpdtopcop's Avatar
Saab
Well I did smell something odd inside the cabin before this started to happen? Which speaker?
I am sure the door panel being pulled is not a simple job. Lol
Old Jun 4, 2020 | 04:43 PM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 4, 2020 | 04:46 PM
tpdtopcop's Avatar
Saab
Thanks for that. I have nailed down sound to the passenger side rear deck? Subwoofer mayb
Old Jun 4, 2020 | 06:44 PM
'71 Pinto
Attachments cover rear shelf. Here are parts #s if it proves to be speaker(s).
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 4, 2020 | 07:24 PM
tpdtopcop's Avatar
Saab
Thanks for all the attachments
Old Jun 4, 2020 | 07:40 PM
tpdtopcop's Avatar
Saab
Do you have part numbers for sub and amp?
Old Jun 5, 2020 | 02:30 PM
'71 Pinto
See post 9 above for sub, here is amp.
Old Jun 6, 2020 | 06:55 PM
tpdtopcop's Avatar
Saab
thanks for everything.
Old Jun 7, 2020 | 12:57 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
And pull your amplifier right now. It will continue melting speakers one by one.
Old Jun 7, 2020 | 01:10 AM
'71 Pinto
Amp in post 12 is for sub, here is system control amp.
File Type: pdf
File Type: pdf
Old Jun 7, 2020 | 07:43 AM
LILBENZ230's Avatar
So is that the failure method for these? Defective amps melt speakers? I thought it was something to do with ambient heat. It seems that only 2014s are affected.
Old Jun 7, 2020 | 01:11 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Hmmm..... The fan for the amplifier back on the rear deck can be mighty noisy at times in my 2016. I wanted to have it replaced under the new car warranty, but my work guidelines precluded me getting out of town to make an appointment and now the warranty is expired. Could you post a price for the amplifier assy if you go that route?
Old Jun 7, 2020 | 01:48 PM
LILBENZ230's Avatar
I show the 2016 amplifier part number is 218-900-14-08 - list price is $1100 but easily found cheaper. This is a different part number than the 2014s.
I've yet to hear a fan running on mine.
The amp part number listed in the EPC that konigstiger posted 212-900-62-26 will show that it has been replaced by 212-900-86-29-80, so hopefully that means the issue is fixed?
Old Jun 10, 2020 | 09:41 PM
ccww's Avatar
2015 E250 Bluetec
Thank you very much for the useful documents.
I am trying to figure out how to remove the anchoring lugs in the trunk as indicated in the "212 trunk paneling.pdf" document. Any help would be greatly appreciated.
Old Jun 11, 2020 | 11:49 AM
'71 Pinto
Carefully pry off cover to expose bolt below.
Old May 2, 2022 | 10:32 AM
mersum1es's Avatar
W211 320CDI -04, W210 270CDI -01
I have same symptoms; rattling front speaker (dead now) and now frequently popping pop-pop-pop sound from rear.... BUT I don't have extra amplifier according EPC?
