steering wheel shacking when braking
2010 e550 p2
Hi all , went to Lake Tahoe , and noticed that going down hill and applying brakes at 55mph and up
my steering is shacking very unpleasant.
i thought it was the warped rotors but i do have a new ones that i installed about to weeks ago...so i doubt its that.
also rear ones were changed about a year ago they all seems fine.
one thing i noticed though which may relate to this issue is that when the car is off , and i turn the steering wheel left to right and right to left it makes a sound like something is loose.
what can cause a vibration on high speeds when braking ? any ideas?
im suspecting a steering gear actually , but before i take it to the shop i wanted to see what others think.
thank you!
thank you!
Its the front brake rotors. They have slight warp. From what I've read there seems to be an issue with mb rotors. My 13 does it above 50 and exaggerates as they get hotter. Being in this industry for quite some time, my "over the internet" diagnosis is rotors.
2012 E550 sedan 2019 E63 Wagon
if you can find my thread about the brembo NAO pads and rotors I bought, they have been awesome. The factory ones after a couple of hard stops started vibrating.
The 2014's switched to the same pads, and they don't complain about them as far as I have seen.
^ Yes, the 2014 does not experience these issues with pulsing stops.
Received 1,144 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
Yes, I was wondering as well, I also have drilled rotors and they are noticeably larger than my 12"s rotors in the front. The back looks the same. I believe my 13 stops faster also. could be part of the Sport package or AMG package? My 13 has all the AMG options without being an AMG, Wheels, Steering wheel, ground effects, 677 suspension, and rear air dam on trunk. Also unrelated my 12 gets way better gas milage than my 13, with both in eco, I get 27 average in the 13 and 31 in the 12.
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 1,754 Likes
2016 E350 Sport
I like Akebono pads and believe that is what I have on my car. I swithed to Akebono pads on my C320 several sets ago and haven't looked back.
I do not have the QO6 code listed in any of the VIN searches I have for my car. I just did the LASTVIN search and not there either. Perhaps it's just a standard for the later E550 4Matic. My brakes have always been great and I believe the pads are Akebono. The Brembo front calipers are pretty massive.
Look at this one https://www.lastvin.com/vin/NLpwWEbW5Zq2Bz8a5 I wonder if it random.
The following 2 users liked this post by S. Madman:
KEY08 (07-23-2020),
pierrejoliat (07-23-2020)
2010 e550 p2
A little observation... before i Had GG brake pad rating with the new rotors i got FF rating which can withstand higher Temps. But they both shimmy the same.
Im guessing pads and rotors have nothing to do with my case.. as i only feel the SHIMMY in the steering wheel not the brake pedal.
im gonna take it to the shop next week.. but im thinking either the steering rack or control arms.. as i replaced them with not oem ones about 50k miles back.
Yes mostly, I have a black plate with the MB logo on it on the 13 but the calipers are the same, the 12 has solid rotors and the 13 has cross-drilled rotors that are slightly larger in diameter. My 12 does not have QO6, but it's listed for the 13.
My pad and rotor combo cured that.
Also look for debris on the inside part of the rotor. Another thing you want to avoid is throwing water at extremely hot rotors (is car wash or sudden puddle or rain). That will really mess up your breaking system.
Next inspect the rotor, and see if it looks shinier on some parts more than others. That would indicate a stuck or failing caliper, or that metal from the pad is stuck on the rotor.
If it got better when the new ones were installed, and then it got bad again, I am almost 100% sure its your brakes.
I've heard the theory of water on hot rotors being bad, but I have washed my car (and every car I've ever owned) after drives with brakes so hot they steam/evaporate water instantly. If this could seriously damage a braking system, it would do that to every car through every automatic wash in the country.
Perhaps if you've tracked the car to the point you're boiling fluid and near brake fire.. but in normal driving, nonsense.
2010 e550 p2
Same here it was only on the steering wheel.
i went today under the car to check tie rods - no play (was able to twist it by hand , not sure if its okay to be able to twist them by hand , since its got a ball joint (speaking of outer) but otherwise all solid , CAN SOMEONE CONFIRM THAT ITS OKAY FOR THEM to be manually twisted PLEASE????? THANKS)
control arms - all solid no play
all of the sway linkages and mounts - no play
inspected rotors and brakes - all smooth no grooves or anything obvious
also double checked and tightened wheel bearing , steering became a little stiffer but made no change to braking.
tires are still in a decent shape.
the only ONLY is the steering column makes a little clunking noise when car turned off and stationary (steering wheel left to right) right in the steering gear or linkage by it.
did balance my tires before i got the new rotors and brakes
and while driving straight its smooth as well.
very annoying , but will take it to a shop on monday.
thank you people.
belarus27 (07-25-2020)
