DIY: Kremersino Wireless CarPlay for NTG4.0
my Kremersino CarPlay adapter runs the following software stack:
Software: CIB_8818_5G V3.10.8.0426
Hardware: 03-0010-06-00-00-00-00-00
System: Linux. 3.4.0_2022-03-30
BlueTooth : BT825,V5.5.0
MCU: benz.ntg45_3.3.0_1_16
Does anyone have a newer version? Where can I get firmware updates from? Kremersino is not reacting to my requests...
Thanks!
Thanks!
Everything went pretty smooth, mainly because of all the posts here, thanks to @S550e , @cadetdrivr and @deeoh !
First I started with pulling everything apart, that was pretty easy and quick, made a picking tool for the vents from a hanger, and otherwise all you need is a T20 and a T10 in my case for the MMI (if you have one).
I almost gave up a couple of times, because I could not see clearly in the dark garage and told myself: "nah, I will wait till the weekend, just put it back together".
And suddenly I got this view:
From here there was no return!
The cabling is pretty straight forward based on the video, I have also used an other one where they are installing an Android screen for a W204.
I have to say that things were easy and flawless until the head unit is out. It is DEFINITELY the worst part of this job, to get the head unit back. I stuck the LVDS box and the harness behind the AC unit and somehow it is back flush, but I'm still not sure if the original cables and the harness getting a strong push downwards as the HU is sitting on it and might break them. I am thinking about checking on it when I have time, or the less touch the better?
So HU is back, glovebox still out, pushed the MMI connector into the glovebox, removed it's housing with the two T10, and there is a pretty big hole on the top of the glovebox, easy to fit in all the cables. I wanted to be smart and reroute the MMI cable (and all the Carplay cables) below the AC pipe, what goes to the glovebox, but soon I understood why it was that way: otherwise the glovebox does not fit back to it's place
.Right now my glovebox is a mess of cables, I have to arrange them, but did not have the nerves after installing it, I was happy to get everything back in place.
Turned on the radio, I have sound, that's a good sign, screen is flipping out, woohoo, time to long push the call ending button! The Carplay screen came on for a second, then it all went black, no worries, we know what to do, change the dip switch! Solved the problem perfectly! Paired the phone and bamm, there is the Carplay in my 10 years old Merc, could not believe it!
Tried the sound quickly, there was none, so no worries again, we know what to do, entered engineering menu (did not exactly do as it was shown), turned off UCI in TGW Parameter, that turns off the MMI port and lets me enable AUX in HU Parameter, so the car thinks that a normal 3,5mm jack is installed (I guess the box is wired that way), and bamm, there was sound, everything worked as it should!Ah almost forgot, clipped the microphone on the vent harness as advised, tried Siri once, it works perfectly! Much easier place to have the microphone, installed in no time, no need to tuck the wires etc!
Well that's where I am now, the installation took a bit more than 2 hours. In the next couple of days I will test it, but so far after a short drive I must say it is perfect, worth every penny! What I will keep an eye on now is the battery life with the navigation and the constant connection.
I really hope that this post is not a mess, tried to go step by step and type my experiences. All in one: BIG BIG thank you for @S550e , @cadetdrivr and @deeoh , you guys ROCK!
EDIT: I knew I will forget something... Regarding the connection time, my experience so far is that it depends when you unlock the car. I guess the box starts to boot up, and connects to your phone while you get it. In the garage it's pretty hard to get it, the other car is close so it takes more time, by the time I start the car Carplay is on the screen immediately. The other time I got in quicker and I saw the activating Carplay screen for about 2 seconds. Either way I would say it's an immediate connection
I need help, when I hold the put down phone button the screen come up for a second and then goes black.
can anyone please help?
This is my current CarPlay setup:
NTG 4.5
Software: Limcet-P305 V3.7.8.0225.1
Hardware: 02-0006-06-00-00-00-00-00
System: Limcet_2021-03-19
Bluetooth: BT825,v5.5.0
MCU: Limpet-V1.0-1125
I have emailed Kremersino on their website and provided them the information they asked for and I am still waiting on a response. its been two days.
TouchScreen=1
MSNEryPortName="/dev/ttyS2"
MCUPortName="/dev/ttyHS0"
WLANType=4
It's possible all that has to be deleted is the first line, I haven't tested this (I was just glad to get it working again). I had originally tried changing it from 1 to 0, and that didn't fix it.
