Interested in an E 550 but I have a dilemma...
I would say, regardless of who's selling the vehicle you should be able to get a PPI done by a local MB dealer or indy. Second, if a MB dealer is selling it they should be able to provide a service history (usually requires current owners consent). Third, service history doesn't mean there aren't current "issues" with the vehicle.
41k for a '12 is very low-miles... almost unreal.
Go to the car and ask the seller to give a few hundred miles "cancel the deal" warranty or ask them to give you the car for a few hundred miles test drive. Fill engine oil to a precise mark on the dip stick and go drive it for those few hundred miles and check if oil level holds. That would be my concern if oil changes were not none by the schedule and engine damaged because of it.
If it is a 4Matic then there is another concern with the transfer case. Problems with that you can feel/hear when driving sharp turns on pawed parking lot or other non slippery surfaces.
But hurry up, there are others wanting to buy E550...!
https://www.cars.com/vehicledetail/d...9135/overview/
I flew from WI to MA to purchase my E550 because it had low miles and all the options I wanted. I didn't do a PPI.
Good luck
Good luck
Good luck
The OP on the topic is too worried about the service records other than if the records would indicate problems with transfer case that were not fixed. If there is an issue I would ask seller $4000 discount and drive the car to MB dealer or other shop who know what to do to get it fixed. This would be about $3000 extra cost on top of the original price of the car, which would still be a steal for the mileage it has.
Get a scanner. I like my Autel AL539B OBD2 Scanner, $100. Read any codes present plus look at live data on test drive. Lots of YouTube videos on this scanner to teach you how to use it.
By the way, my 2012 E550 4 matic has 203,000 miles. I do have something going on. Small antifreeze loss (a ouce or two every other month) suggest head gasket. All o2 sensors are shot. Makes the fuel trim go rich.
Good luck.
