Sponsored by: CARiD
Deep growling sound and vibrations at certain speed and rpm
Old Feb 22, 2021 | 12:38 AM
Husstab's Avatar
W212 E350
Hello,
My E350 automatic has been doing there weird growling sounds and vibrates when the rpm reaches 2500 at relatively slow speeds (30-50 mph) especially at the 4th gear (at 3rd and 5th symptoms still present).
i tried shifting transmission to neutral when the growling and vibrations occur and magically they disappear (obviously the rpm goes down to roughly around 1500, so i don't know if the problem is from the engine or the transmission)
Am I missing something?
Thank in advance for your help.
Old Feb 22, 2021 | 08:27 AM
RA72825's Avatar
4Matic? Sounds transmission related. When was your last transmission service?
Old Feb 22, 2021 | 08:33 AM
Husstab's Avatar
W212 E350
Not 4Matic, I am assuming that the sounds and vibrations are transmission related because when the symptoms occur, I hit neutral and they vanish.
Transmission serviced according to car’s manual.
Old Feb 23, 2021 | 07:28 AM
DeutscheBenz726's Avatar
2019 E 300 4matic 2013 SLK 250
Is there a jerking feeling that goes along with the growl? If so it may be the torque converter
Old Feb 23, 2021 | 08:12 AM
Senecan's Avatar
1983 Nissan SHlTBOX
Not sure why, because I'm not that smart, but I have a hunch you'd figure it out if you got under the car and did a thorough inspection...
While you're under there, check these:
https://www.mboemparts.com/oem-parts...bC12Ni1nYXM%3D
Old Feb 23, 2021 | 09:28 AM
Husstab's Avatar
W212 E350
no jerking nor hesitation just a deep growling sound inside the cabin along with an unusual vibration felt when resting hands on the middle compartment (between driver and front passenger). It lasts until the car automatically shifts to the highest gear and then it reappears at roughly the same rpm on this new gear (especially 3rd, 4th and 5th).
I hope I am explaining the symptoms clearly.
Old Feb 23, 2021 | 12:44 PM
Senecan's Avatar
1983 Nissan SHlTBOX
...vibration felt when resting hands on the middle compartment (between driver and front passenger).
No kidding? lol
Thank me later.
Old Feb 23, 2021 | 01:17 PM
MBNUT1's Avatar
2010 E350 4Matic
If it is RPM related then it is not the flex disk as suggested above.
Old Feb 23, 2021 | 01:43 PM
Husstab's Avatar
W212 E350
Originally Posted by Senecan
No kidding? lol
Thank me later.
I will take it into consideration!
Because I was just parking today in a rough terrain and unfortunately I had a stone stuck under the middle end of the car, so that I felt the vibrations, on P, N and R!
I will get the shaft checked
Old Feb 23, 2021 | 01:55 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
I was going to ask if you felt a vibration in the steering wheel and/or floorboards when starting the engine cold, putting into gear with the brake depressed.
Old Feb 23, 2021 | 02:09 PM
RA72825's Avatar
Perhaps an axle if no vibration in the steering wheel and body shaking like mad.
Old Feb 23, 2021 | 02:33 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Have you checked the engine/transmission mounts?
If the mounts have collapsed, then the engine vibration is transferred to the chassis.
They are known to go bad, and are typical replacement items at higher mileage/age.
Old Feb 23, 2021 | 06:10 PM
Senecan's Avatar
1983 Nissan SHlTBOX
Care to elaborate? Because that's actually a classic sign of that exact failure.
Old Dec 17, 2024 | 04:25 AM
gr8dzynr's Avatar
2012 ML350 Bluetech 4Matic, 2012 e350 cabriolet, BMW S1000R GEN 2
Hello,
did you ever figure this out?
