Parasitic Draw Recording and Xentry Monitoring
Quick parasitic current measurement with car off after a few minutes only indicated a 10-20 mA draw, totally normal. Hooked up a DMM capable of recording (OWON B35T+) and let it run for 5 hrs (randomly picked) with car off and locked. Sure enough there was draw/activity and even a large spike to 5.5 A indicating module/s were waking up. The large spike at the end was in the middle of the night and not related to unlocking the car or touching recording the equipment.
Spoke with a friend who indicated there's CAN monitoring built into vehicle and it can be read with Xentry. Sure enough, in Xentry we were able to see the interior CAN was active (not normal). In this case, the car will need to go back to dealer and have a CAN bus recorder installed. The recorder logs all activity and is used to further diagnose why certain modules may be waking up. Definitely a complicated issue and unfortunately a lot of time to figure out.
I looked at my '11 E350 and it doesn't appear to have the same "level" of monitoring, but it does have a feature recording the last two events that kept the BUS awake. For this W212, Navigate in Xentry: Central Gateway (CGW [ZGW]) > Actuations > Bus keepawake unit detection
I tune my Maxima ECU with RomRaider and a laptop. I've got several edited ROMs I switch back and forth between. I might be feeling the need, the need for speed one week +20% base fuel map, then have to pay for it the next with the economy ROM.
you hook an ammeter up in series with whatever you want to measure. if you want to measure the whole car, you would disconnect the positive lead from the battery, and connect the meter to the battery + and to the positive cable. make SURE the meter is in amps mode when you do this, and make SURE you switch a multimeter OUT of amps mode as soon as you're finished with doing this.
if you want to measure the stuff on a single circuit, you can remove that circuit's fuse, and connect the ammeter between the two fuse terminals.
probably all these with courtesy light set to light with the door open, I forgot.
So when using an amperage meter function of a digital voltmeter aka "in-series", be careful because usually 10 AMPS is the fast fuse value in say a Fluke and some
have 400mA ones also, to read the finer amperage. Fluke 10Amps fast fuse is expensive.
What I have not tested is , let say car is locked for say 2 hours and then the FOB key I bring closer to the car.
I wonder what will wake up when I do so.
It takes at least 30 minutes for my car to really "sleep" and and draw the sleeping mode power consumption.
When you want to read very low values of say 20 milliamps or less, you can use a 2A capable clamp-meter, but do be careful when near metal or how not-in-the-middle one position
the wire in the clamp sensor region. One way is to lengthen the jumper wire you want to sense and lift it up and away from the car metal at least 50-70cm. This is because DC we are reading and
its a pain in the azz at such low milliamps when using clamp meter, unlike AC voltage even at same 6 milliamps which its switching poles type magnetism at 50 or 60 hz is not easily replicated by us and thus the
clamp sensor which reads magnetism won't be fooled.
See below how a clamp amperage meter, el-cheapo one but very good for 2Amps and lower current value, can finally read close to a in-series multimeter accuracy
The same clamp meter when exposed to the magnetism surrounding the battery post, read 300mA ...LOL, by which it should be under well below 50mA even if I was not recording the video past 30 minutes after engine off and door locked and hood also locked. I know this meter auto off is like 10-15 minutes only.
Behind the Uni-T clamp meter is the yellow Fluke 381.
See even Fluke at such low amperage reads 400 mA LOL due to its huge claw......worse than the red Uni -T baby claw.
However this Fluke a 2,000 amps DC/AC wireless clamps. So below 1 amps, best not to use it, but I need its wireless function and its high DC amperage capability.
and used this for inspiration: http://colintd.blogspot.com/search/l...0Common%20Slot
I struggled with how to properly connect a large gauge wire to the PCB pad of the PS. With the header, I soldered two large copper bus bars and then to those connected the wire with ring terminals. Still a work in progress and I'd like to "package" it better.
https://nl.aliexpress.com/item/10050...archweb201603_
as long as the car alternator puts out 14.4-14.6V but absolutely NO more than 14.6V, you're good enough. once the batts are 100% charged (current drops to zero at 14.6V), then a lower voltage like 13.6 will maintain the charge, most car alternators do something pretty close to this.
https://www.dcpowerinc.com/products/...altima~le_3-5l
