Sponsored by: CARiD
Code u0103
Old Mar 22, 2021 | 11:02 AM
Devon West's Avatar
2014 e550 sedan
Code u0103
I replaced the up shift paddle shifter because it was broken by the previous owner. Now it doesn’t work. Do i have to Program it ?
Old Mar 22, 2021 | 12:22 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Physically broken and/or not working?
Code U0103 indicates "lack of communication with the electronic selector lever, module has a malfunction"
Does the column shifter work? Does the down-select paddle work? How about the other buttons on the steering wheel, multi-function and horn.
Any other codes? The paddle shifter is part of the steering wheel, IIRC and I believe the electronic selector lever module is part of the steering column module. Hmmm...
Old Mar 22, 2021 | 12:42 PM
Devon West's Avatar
2014 e550 sedan
everything works besides the upshift paddle. Previously it was broken the up shift paddle and i replaced it with the same part number
Old Mar 22, 2021 | 12:46 PM
nota_amg's Avatar
2013 SL550 BiTurbo
curious if it was broken from previous owner pulling too far because of another issue causing it to not register? Possibly a module/shifter issue that needs to be addressed as well?
Old Mar 22, 2021 | 12:55 PM
I can't speak from experience with this specific issue... but my first step would be looking at live data, probably thru the steering column module, and verifying whether the module "sees" input from the paddle. I might try clearing the code and retrying the live data exercise.
Then proceed from there.
Old Mar 22, 2021 | 01:43 PM
Devon West's Avatar
2014 e550 sedan
he had a paddle extension on it and it broke of stuck to the paddle extension
Old Mar 22, 2021 | 02:44 PM
Devon West's Avatar
2014 e550 sedan
i fixed it. I took the stuff out of the new paddle shifter and put it into the old one.
Old Mar 22, 2021 | 04:08 PM
Please do, further elaborate...
