2012 e350 Front seat anchors
Anyone know how to remove the driver’s side seat cushion on a 2012 E350 and what the seat anchors should be torqued to? Looks like the seat has to be tilted back to remove the storage bin attached to the front of the seat.
Received 1,008 Likes
'11 E350, '11 E550, '98 M3, '95 E320
The bin can be removed easily, just slide the seat back and there's two torx screws securing it at the top to the seat frame. The lower cushion can come out without removing the seat. What are you trying to do? I know there's a procedure around, search for seat cushion tear/removal.
pierrejoliat (04-11-2021)
Received 1,128 Likes
12 E350 4Matic 13 E350 4Matic AMG Sport
Received 4,435 Likes
'71 Pinto
pierrejoliat (04-12-2021)
Thanks for the continued info. It’s pretty easy on a 2012, once you’ve done it. The only wire going into the cushion is the seat heater. I’m having an issue trying to disconnect the small wire connector for the seat heater. Is there a special tool for this? It’s plugged into a junction box at the base of the front seat frame.
I have found that Benz connectors in general are difficult to separate????
I think this video would be very helpful:
pierrejoliat (04-13-2021)
Thanks.... I just cut the wires and installed a two wire connector.... Anyone working on a 2012 E350 4matic will want to read this thread.... I’m surprised more people haven’t made inquires into this topic....
No need to cut anything. I’ve had the cushion out twice once to replace the side trim and another to install washer to fix slop in back seat.
pierrejoliat (04-14-2021)
