Clunking Noise Driver side
Any ideas on what it might be or how to further try to diagnose the issue?
I recorded a video of the sound while driving. The noise in the video is more muffled that what it really sounds like.
https://youtu.be/DUYJ480PD1E
For me this sounds exactly like I had it when my front struts went bad. This noise appeared before the bags started leaking and it was gone after I replaced the front struts with the OEM re-build parts from FCP Euro.
I heard that someone else re-builds these struts but only replaces the leaking spring bag. They don't fix other internal issues in the shock absorber, which is where the clunking sound in my car came from.
Like I said, it sounds the same, but could perhaps be something else?
I got Arnott front struts from Summit. I installed them earlier this month and the noise came about 2 weeks after. Everything was fine in those 2 weeks.
All of it is connected so it makes sense, mine was on the driver side and it subsided as the car got temperature in it.
This is the video I mentioned earlier:
The sound in his video sounds pretty close to mine and his issue was sway bar links. Thoughts on that?
Also, I noticed the boot covering the airbag on my strut was not secure to the top. I doubt this caused the problem but small chance it's possible? Assuming there's a tiny gap where the boot covers the top rim.
You won't know till you check them... as rapidoxidation said, get in there with a pry bar and manipulate the control arms/balljoints/bushings... checking for play. Before you take off the wheel, grab the tire at the outer edge and apply back/forth force at 9:00 & 3:00 and then 12:00 and 6:00, checking for play.
The boot on the strut keeps debris out... I don't see it causing clunking. Causing the bladder to rupture... sure.
I have a clunk on my E550 from the front passenger side. First thing I checked was the swaybar links... their tight (10 years old, 100k). All the balljoints are good as well. The only bushing that's "suspect" for me is the thrust arm. I plan to change them... if it doesn't resolve the issue, then I'll install a set of chassis ears. I have a suspension that it could be the strut...
How similar is your clunking noise to mine?
I went in with a pry bar to check behind the tire. The control arm had very little play. Same with the sway bar link. The sway bar link was pretty snug but i was able to twist it back and forth about 45 degrees. The 3rd piece that is perpendicular with the wheel (I don't know the name of this one) is also pretty snug and does move much.
Dunno if thats what your car may need but worth a look.
I swapped my 2 front sway bar links and that seemed to have fixed the issue! No more noise! Ride seems smoother too or that could just be in my head since I don't hear a rattle lol.
