Rear Radar (Blind Spot)???
I'll have a look then...
Peter
Any ideas how to get the electrical connector off, and then drop the sensor from the holder?
2012 E550
TIA
First go to EPC to get your radar P/N, the correct one.
Then you go to ebay and take a look, often their image is of very high resolution and the connector locking mechanism sometime is visible.
Example here image #6 : https://i.ebayimg.com/images/g/U9QAA...9d/s-l1600.jpg
May not be your exact P/N, but you will get what I mean.
2nd method is, at the same EPC, the connector P/N for radar may sometime be shown, you then search for that P/N too for its high resolution image.
Your issue is most likely a crusted up connector.
So basically its like being "glued" by crusty.
If the video I linked at post #26 is the very same radar module on your car , watch it slowly as the connector design is so clear there.
https://mbworld.org/forums/e-class-w...ml#post8564491
By looks of it , the locking mechanism of the connector is indeed the push in type to raise the locking lever.
https://www.ebay.com/itm/255521380811
It seems the A , I marked in red is where you must press, and only A region.
Have a try.....
I did take a look online for a similar radar detector, but none of the images I found clearly showed the connector. I wish the video was a little clearer too.
As an aside, I really dislike all of the different connectors on these cars.
I was youtube assisted when I tried to remove my friend's W204 ABS big multiple pins connector...
The way to open it up is like the ECM but not very similar...so crude hahahahah
Thanks to @konigstiger and @S-Prihadi for their help here!
In this image, my original is on the bottom. You'll notice what numbers are the same to ensure it is plug-and-play.
