Oil Leak at front of intake manifold
I have a 2010 E550 Base Sedan.
Any assistance would be appreciated.
Thanks,
Stephen
A good amount of the overflow that makes it past the dirty valves normally gets combusted... Some engine feature a small overflow tank to prevent dumping oil directly on the garage floor... clean luxury.
I am not sure any new PCV parts can help keep oil out of this design.
How much oil between oil change are you loosing?
My M276 has been drinking 1 Qt of oil since new.
Anyways I will check the consumption on the next change.
That's quite a bit of oil though 1qt, my old diesel benz just barely hits 1qt (6k miles per oil change) and it has all kinds of little drips. I think I have replace about half the gaskets.
I would start with the separator at the rear of the passenger-side cylinder bank. There's a hose that connects the cover to the TB, disconnect and look for signs of oil in the tube. Usually that cover starts to leak down the back of the cylinder (super common issue). So I'd reaplce the cover and the seperater "donut" attached to the cam as well.
The other separator is on top of driver-side cylinder bank (front) like a black plastic box with a hose that runs back to top of TB. Same, disconnect the tube and inspect for oil.
https://www.fcpeuro.com/Mercedes~Ben...&b=5&d=3498&v=
Many lever repair kits out there. When the lever breaks that's a sign that the flaps are getting gummed up. If you replace it with a metal lever, the lever doesn't break and it eventually forces the flaps to break which causes engine damage.
https://www.ebay.com/itm/303700145431
-Stephen
What'd you replace it with? Another Mercedes-Benz I hope.
