Sponsored by: CARiD
Front full knuckle replacement.
Old Aug 17, 2021 | 08:32 PM
matthewvee's Avatar
2013 E350 RWD Sedan
Has anyone done a full front knuckle replacement? Looking for steps/advice/instructions.
Old Aug 17, 2021 | 09:02 PM
chassis's Avatar
2017 GLE350 4MATIC
Is it already posted? How much have you used the search feature? @konigstiger will know if it is on this site.
Old Aug 18, 2021 | 01:04 PM
konigstiger's Avatar
'71 Pinto
See attachments.
Old Aug 18, 2021 | 01:13 PM
matthewvee's Avatar
2013 E350 RWD Sedan
This is awesome, thank you!
Old Aug 18, 2021 | 01:33 PM
matthewvee's Avatar
2013 E350 RWD Sedan
So directions apparently easy as heck for removal but this…
I ended up removing the old steering knuckle, pretty easily. I purchased a new steering knuckle or someone new from a scrapyard off of a 2014 model with only 39,000 miles… The part looked great online, and is in amazing condition other than for one problem. The strut rod has to go into this hole on the knuckle. As you can see from my photographs, the first one is my old unit, hole is perfectly round and the second one is the new unit, The hole on the new unit looks like it was damaged upon removal or maybe this vehicle was involved in some type of curb damage etc. I am having a hard time even getting it to fit I’m wondering if I install it with a little force if the strut rod connections could become damaged? Maybe should have gone to dealer for a new one. So damn expensive though. Am I gonna create another problem here.
Old Aug 18, 2021 | 01:59 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Did yo see how much a replacement would be from FCP Euro or Autohaus AZ? I don't think I'd use that one with and ovalized center hole.
Old Aug 18, 2021 | 02:01 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
I wouldn't use it... send it back. Why are you replacing it in the first place?
Old Aug 18, 2021 | 02:03 PM
matthewvee's Avatar
2013 E350 RWD Sedan
FCP did not have it, I agree that oval hole scares me. TY.
Old Aug 18, 2021 | 02:05 PM
matthewvee's Avatar
2013 E350 RWD Sedan
I am sending it back - I don't want to cause further damage to vehicle.
I was ripping through wheel bearings like every 5000 miles, I think the axle spindle was actually bent from a winter pothole when the first bearing blew.
Old Aug 18, 2021 | 04:31 PM
RA72825's Avatar
Totally fubared. It also appears that the casting is cracked (left side of your photo), unless that's just some kind of dirt/grease mark.
Old Aug 18, 2021 | 09:29 PM
chassis's Avatar
2017 GLE350 4MATIC
It's knackered. Don't use it. Try to get your money back. I would buy a new knuckle. The front knuckle is arguably the most safety critical part on a vehicle.
Old Aug 19, 2021 | 07:58 AM
ygmn's Avatar
2015 E400 Sedan
Go NEW!!!
My guess is most in the junkyard have hit a curb or pot hole in their life and may not be better then yours.
Good Luck
Old Oct 18, 2021 | 02:55 PM
amgw463's Avatar
AMG G63
Hi, these PDF files are great. How/where do you get them? thanks, shawn
Old Oct 18, 2021 | 09:34 PM
chassis's Avatar
2017 GLE350 4MATIC
Buy and download EPS/WIS/ASRA from ebay. You need to be relatively tech savvy to use it because it runs on a virtual machine and the downloads are very large.
Old Oct 23, 2021 | 10:24 AM
amgw463's Avatar
AMG G63
Thanks a million for your guidance. Do I need to buy a subscription (perhaps not) or just buy the 2020 workshop (such as this)? Also, when I buy, is it only one file or do I need to buy a separate file each time. Thanks, Shawn
