Help! Where is N70b1 temperature sensor?
Here is a related thread... https://mbworld.org/forums/e-class-w...nsor-code.html
I’m glad you posted this! I have the same iCarsoft scanner and on my 2015 e63 it shows same -50 degree value on that “interior temperature sensor with integrated fan”
did you figure out what it was? I’m trying to figure out what sensor to replace.
The scanner doesn’t show that there’s a code on that or a fault, which is weird?
super appreciate all your findings here that you shared. !!
I always advise to start AC troubleshooting with temp sensor calibration test, as this is the easiest way to start and often can find the culprit without getting your fingers dirty.
Checking refrigerant pressure on variable output compressor is tricky.
I usually leave the car in hot spot for the test and when I start AC with interior temp about 40C, that will give me couple of minutes at max output to measure the pressure.
Fully charged system on hot day should exceed 30 bars, when 25 seems to be acceptable.
My updated Autel Maxidiag has been showing me partial faults with :
- OCP TempSensor bogus Temp
- TPMS tire pressure data memory
- RFK Rear camera calibration
Where using a Xentry confirms no problem present.
So that's an additional grain of salt to keep in mind with 3rd party "compatible" scanners.
Show us picture of the circuit board as you see fit.
Use your cReader Elite scanner to help read values and test procedures.
Note that not all "MB compatible" scanners support all functions of all modules... ie. "mileage may vary!" Autel Maxidiag scanner showing wrong data.
What sort of value was your Carly scanner showing:
a crazy -50F temp (bad scanner)
or
a little bit lazy 63°F due to dust collection?
How about your HVAC Controller live data...
All sensors were reporting a realistic temp value, but the OCP sensor was -50! On inspection, it was very dirty so I thought id try a deep clean and see what impact it has, ive yet to test it up to temperature yet, nad have reset all error codes ready for a check in the coming days.
Im not sure what the HVAC control live data is? I was going to leave it a few days and try it on Carly again to see what it discovers...
- on 17/16 degrees its cool, but not 16/17 cold *feels more like 20/21
- but on 'LOW' it goes to full chill
Feels like the temp settings could be adjusted as the AC is obvs working fine, as is the heat...
Question: is there a calibration exercise I need to do so the 'head unit?' knows the correct temperatures? Or should I consider replacing the temp probe in the OCP? Which looks like it's above my soldering skill level
Massive thanks in advance 👍
I'm not sure what the HVAC control live data is? I was going to leave it a few days and try it on Carly again to see what it discovers...
I think you've gone as far as simplicity goes. There are multiple issues involved with the true cabin temperature.
One is the hot coolant is always circulated through the dash as there's no shut off valve. Its nice in winter, not so much in summer heat. The whole idea behing that is to dry the misty evaporator and prevent windshield foging.
There are experimental ways to reduce the engine heat by enabling the piston oiling near 1K.RPM.
Also you can bump the AC efficiency by insulating 200F engine heat out of the high pressure line.
HVAC actual live temperature data are found using a suitable scanner on the AAC Module. Some handheld scanners are more limited than others.
The pet scanner around here is the "cReader elite MB by Launch" priced around $150 AMZ.
Clean/replace cabin filter for good flow.
Lube the squeaky cabin blower fan helps push air through the system.
Enjoy regulated temperatures.
I have yet to attempt to open up the OCP and inspect/clean that as I'm fearful I'll break some of the plastic tabs while trying to remove it and never get it back on... maybe i just need to do that.
In other words your issues are not caused by this good sensor.
Read the HVAC module for active issues.
It's strange your sensor runs all the time ...
these sensors are dust sensitive to get all plugged up.
OK, so cleaning this OCP sensor didnt work
And like me you are now looking at options to replace this sensor!My current logic is: the HVAC will only blow cold on 'LO' as this setting doesn't need to know cabin temperature! But with all other settings, HVAC will be out of wack - as the OCP sensor is telling it it's -50. So it will continue to deliver heat...
BTW: I also worried about breaking a plastic tab when taking OCP apart, but it came apart ok with some logical effort - remember there are screws under the center object and the sticker
Once unscrewed, you don't have to separate both sections to get the PCBoard out.
Good luck bud
This LIN sensor works well regardless of limited support compatibility by some scanners.
Im not very car-technical so don't know how best to diagnose where else the problem might be
What are you trying to diagnose?
I thought, I have the same problem like this. However, when I opened inside of the panel, there was not any fan or sensor. When I opened the panel, the security paper was also punctured. From what I understand, the previous owner of the car removed it and threw it away. You can see in the images. For last 2-3 hours, I am searching for the name of the fan(or black compenent). Do you have any idea? If I buy a used panel, can I unplug them from there and attach to my panel? I can not find same panel as my car's model. Also I do not want to pay 750 euros.
