Lowering w212 sedan w/o airmatic
currently its sitting on kw v3 coilovers which ride great but i dont feel like they get me low enough..
The angle make it look alot lower than it actually is..
ive got 4matic if that matters.
when you 'bag' it, you will be removing your coilovers anyways, as the bags can't force the existing springs and shocks to make the car lower, they REPLACE the springs and shocks. adding bags to an existing system can only RAISE the car, typically you do this to a hyper-lowered car so you can lift it to go into driveways and over bumps/dips without scraping body parts.
yeah, its that purple ring on the body threads as seen in the top picture here,
https://www.kwsuspensions.com/produc...overs/variant3
yeah im aware! but when adding more preload ride height would definately be higher? or am i not thinking straight? currently its barely preloaded. i have adjustment for compression and rebound also if that could help in any way to achieve the fitment i want.
the damping adjustments (compression, rebound) set how it rides. with not enough damping, the car will 'pogo' and bounce when it hits a bump. with too much damping, the bump will be much harsher in the chassis, and on a rippling road, too much rebound can cause the suspension to 'pack down' as it won't unload fast enough.
I don't think you can get super-low without custom suspension arms to change the geometry, and you would need shocks with a shorter minimum length, and probably higher spring rate, and then you're so low, you need the airbags to drive around everyday bumps without scraping hard parts and skirts.
