Sponsored by: CARiD
Phantom Limp Mode; Did I Blow My Turbos?
Old Oct 20, 2021 | 02:22 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Originally Posted by shockandawe
Funny enough, I am tuned, i'm making 420 to the wheels. I got it tuned by an independent shop who was nice enough to do it for 900. I like the idea of the pipe being split though, so I will look into this as well. Thank you for the idea!
I think I've seen you on the mb subreddit then. I'm running a jb4 on mine, no idea what it's making though. I'm going above what Burger recommends, but their recommendations are for the 43 version of the motor, so far no CELs, but also only 47K
Old Oct 20, 2021 | 02:40 PM
shockandawe's Avatar
2016 Mercedes E400 4MAITIC
I definitely do post in there from time to time showing my car or asking for help lol. How do you like your tune, and is it aggressive or safe. Can you tell me more about the jb4? never heard of it, only renntech when i was looking for tunes prior to actually getting it done.
Old Oct 20, 2021 | 06:08 PM
Arrie's Avatar
i can see that being a cause. i mentioned earlier they got me such a significant power boost for half of what others were charging and i would've gotten less gains.
my power greed did me in (if it truly is a poor tune). i just don't understand how it could be fine and suddenly cause issues
Get a scanner. iCarsoft MB II for about $200 and you can read the fuel pressure.
I don't know what the tune does but part of it could be increasing the fuel rail pressure. A scanner could show you if that pressure is where it needs to be, i.e. at 170 bar minimum when car moves.
Old Oct 20, 2021 | 10:16 PM
DubVBenz's Avatar
Burger motor sports (BMS) are really popular in the BMW world and became that way by tuning up their 3 liter inline 6 turbos (n54 and now N55). They've expanded and offer the same piggy back modules for our motors. It is a piggyback that also connects to your obdII to monitor realtime sensor readings and adjust accordingly. It also has bluetooth so you can change maps, log (and graph) everything obdII logs. They have a handful of standard OOB maps, but you can also create your own. It's not as powerful as a full ECU tune, but I really like the flexibility. I'm not sure if mbworld will allow the link, but here's a shot: https://www.n54tech.com/forums/showthread.php?t=28003
If not, just search online for BMS and Mercedes
Old Oct 21, 2021 | 01:16 AM
just ordered one, thanks!
Old Oct 21, 2021 | 08:28 AM
Fliplegend's Avatar
S212 E350 Estate
+ 1 to BMS. I've used a few of their stuff on my F30 and quality is really good.
Old Oct 24, 2021 | 01:06 AM
  #32
Originally Posted by Senecat
Nice. Sounds like an awesome tuner!
Hello all, an update. Took it to the independent and he found this code (see pic attached): P029900. Apparently, I had too much oil in my engine, and that is throwing my turbos off. He checked my oil levels and they were WAY higher than they were supposed to be. He did a drain, a full oil change, and added an OEM filter and he says that should help. I got it done around 2PM EST.
Its now 1AM EST and after a few hours of putting turbos under heavy load and highway cruising at 85-95mph, the car has not gone into limp mode. Everything seems to be fine (for now). Can anyone chime in, is that possible for too much oil to mess with the turbos like that?
Old Oct 24, 2021 | 04:43 AM
  #33
Senecat's Avatar
1983 Nissan Shltbox
You'll kill a motor just the same by overfilling it as you would underfilling it. Oil level absolutely matters.
Old Oct 24, 2021 | 06:50 AM
  #34
S-Prihadi's Avatar
How did oil overfilled occurred in the first place ?
This 3.0 TT takes in only 6.5 - 6.7 liter of engine oil, with oil filter change.
I hope it is not fuel dilution into engine oil, which is not so obvious by look (if say only 0.5Liter )compared to coolant dilution into engine oil.
I seen a 22 liter engine oil capacity big marine diesel, overfilled by 4 liter and the aftercooler clogged.
That engine design was using aftercooler vacuum for its diesel fuel injection governor system for final WOT RPM .
So the clog caused the engine to not able achieve WOT, that simple. It was a 1995 680HP V8 MAN, non electronic, purely mechanical.
I don't really know how 3.0 TT M276 oil vapor separation would handle overfilled engine oil, but if also your aftercooler get oil load, do keep this in mind
when next troubleshooting.
On M276 3.0TT, there is a Y31/5 turbo pressure transducer.
See page 5 of the attached document
Its easy to remove and undo the hoses, maybe take a look if those hoses internally are wet with oil.
It does not look like a MAP sensor, its cylinder shaped , like a 3/4" pipe.
File Type: pdf
Old Oct 24, 2021 | 09:25 PM
  #35
oh that makes sense, and another day has passed of putting it under HEAVY load, and normal cruising and nothing has happened. I know its only been a full 24 hours, but so far so good. Hope it's permanent.
I will check the hoses on my next free day, and to be honest I'm not sure how it got overfilled. I got an oil change from the actual stealership about 2 months ago and everything was fine up until the incidents. Thanks for attaching this so i can see it!
Old Oct 24, 2021 | 11:58 PM
  #36
Arrie's Avatar
I have never seen any explanation as why overfilling the engine is bad and why you would have low oil pressure with it.
My own thinking is simply that when oil is too high the crank shaft cranks hit the oil surface in the pan and works like a mixer causing oil to mix with air and foam up. This results in low oil pressure as it is kind of difficult for the oil pump to pump the foam.
Nothing else needs to be wrong for losing oil pressure in any part of the engine.
If anybody has better knowledge on this please advice.
Old Oct 25, 2021 | 01:10 AM
  #37
ItalianJoe1's Avatar
2003 CL 600
Exactly that, too much oil makes it contact the rotating parts, which whip it up into a froth, and that froth can't hold pressure due to the air compressing. So too much oil will actually cause a loss of oil pressure with sustained RPM, as eventually the oil aerates enough. Too much and it will start to suck into the PCV system and you will see it burning out the exhuast, but it doesn't have to be 3-4qts higher to cause issues.
Old Oct 26, 2021 | 06:22 PM
  #38
Thank you both for the explanation as i was totally lost as to how overfilling could create such an issue. Just stopping in to say thanks, and to update that the issue has not happened since the drain and refill to appropriate levels. Fingers crossed this is a permanent fix lol.
Old Oct 26, 2021 | 09:16 PM
  #39
Arrie's Avatar
If your oil level goes up you have something leaking into it, which would be the engine coolant. But for that you would have coolant low level warnings pop up...
Old Oct 26, 2021 | 09:33 PM
  #40
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
I would monitor engine oil, and coolant level and color weekly for any changes. Transmission oil can mix with coolant as well, Valeo debacle a few years ago?. .
Summary: you need to understand and be certain where that extra fluid came from to sleep better, and enjoy it even more
Old Nov 1, 2021 | 01:12 AM
  #41
Hello, probably a dead thread since I'm not quoting anyone anymore. Just updating to say the car has been fine ever since the oil change
& thanks juanmor40 for the protip
Old Nov 1, 2021 | 02:11 PM
  #42
Senecat's Avatar
1983 Nissan Shltbox
I pop my hood at least monthly and check everything I can think of. Good practice to avoid an "oops" like this. Glad the beast is tearing up the streets again!
Old Nov 2, 2021 | 03:09 AM
  #43
BenzV12's Avatar
W212 FL
Nice to hear everything is OK
