Retrofit kick tailgate opener
Old 12-09-2021, 12:54 PM
yiannossavva's Avatar
Gcl 220d 2018
I installed the original kick sensor with original keyless go ecu, not working because need programmed key with keyless function!
i will continue with plant b :-)
i already order aftermarket microwave sensor.
i will update when check
The following 2 users liked this post by yiannossavva:
CaliBenzDriver (12-09-2021), pierrejoliat (12-09-2021)
Old 02-18-2022, 10:37 AM
Gcl 220d 2018
Finally i install Chinese kick sensor and works perfectly!
The following 4 users liked this post by yiannossavva:
badbenz94 (02-18-2022), BenzV12 (02-19-2022), CaliBenzDriver (02-18-2022), pierrejoliat (02-18-2022)
Old 02-18-2022, 10:58 AM
CaliBenzDriver's Avatar
Received 3,448 Likes on 2,297 Posts
MY'14 W212 M276 3.5NA @60kMi
nicely done!
What does it take to retrofit the kick function with non-OEM components?
Your kick module is... not coded but works with trunk??
Old 02-18-2022, 11:00 AM
Gcl 220d 2018
No programming needed
just connect the output signal from module to (open tailgate switch)
Old 02-18-2022, 11:13 AM
badbenz94's Avatar
2013 E350 4Matic P2 Pano
So you're saying this can be easily retrofitted to preface lift with keyless go?
Chris
Old 02-18-2022, 11:49 AM
Gcl 220d 2018
If the car have electric tailgate yes
Old 02-18-2022, 12:12 PM
  #32
badbenz94's Avatar
Electric trunk opener. So you don’t need to “pair” any of the modules?
Chris
Old 02-18-2022, 12:15 PM
  #33
Gcl 220d 2018
No just the signal wire
The module needs ground, switch +. Kai memory +
Old 02-18-2022, 01:48 PM
  #34
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
It make sense because all the car cares is that the fob is near you. The kick sensor emulates the open lever under the license plate. On a car without keyless go, the car would have to be unlocked?
Old 02-18-2022, 01:56 PM
  #35
badbenz94's Avatar
So what did you buy to make all if this work? Maybe a quick run down of items needed and how to wire up for those of us not as smart as you
Chris
pierrejoliat (02-20-2022)
Old 02-19-2022, 02:08 AM
  #36
BenzV12's Avatar
W212 FL
Great job, I love this feature as well . It's very useful and handy . Kudos to you as you are able to get it working using 3rd party parts in a Mercedes-Benz
The following 2 users liked this post by BenzV12:
CaliBenzDriver (02-19-2022), yiannossavva (02-19-2022)
Old 02-19-2022, 03:04 AM
  #37
following the trail...
source QR link
Decodes into this URL :
http://www.yeamax.com/2PASS/kic0002B.html
That leads to this document :
aftermarket trunk-kick product sheet
My simplified-CN is little rusty, Google translate!
Sweet find at any rate.
BenzV12 (02-20-2022)
Old 02-19-2022, 05:19 AM
  #38
Gcl 220d 2018
€ 26,31 33% Off | Car One Foot Activated Trunk Boot Kick Sensor Electric Smart Tailgate Kick Switch for Car Trunk Opening Sensor
https://a.aliexpress.com/_mtsZNLi
i buy it from here, cheap and works perfectly!
I install a keyless entry-start module to my car.
when i am close to the car automatically the car unloaded and activate the kick sensor.
The car must unlocked to activate kick sensor.
Old 02-19-2022, 05:24 AM
  #39
Gcl 220d 2018
yes the car must unlocked, safety reasons. When you buy a keyless entry just kick and the tailgate will open without take out the key ;-)
Old 02-19-2022, 05:43 PM
  #40
S. Madman's Avatar
My car is already Keyless Go. I am just missing the kick open.
Old 02-20-2022, 01:32 AM
  #41
Gcl 220d 2018
I am not sure if will work. Your tailgate unlocked when you tucked the handle?
Old 02-21-2022, 02:59 AM
  #42
S. Madman's Avatar
If you meant it for me, yes it unlocks when I pull the handle under the license plate.
Old 02-21-2022, 03:04 AM
  #43
Gcl 220d 2018
If no need to touch the metal part (handle) and open only to push the button will work
Old 02-23-2022, 06:39 AM
  #44
S. Madman's Avatar
The way it works from the factory (at least on my 2012) is if all the doors are locked, and you pull on the trunk handle above the license plate, the trunk opens, but the other doors remain closed.
It has 2 buttons on the trunk to close it, a trunk close button, and a lock (the whole car) and trunk close combo button.
Old 02-23-2022, 06:46 AM
  #45
Gcl 220d 2018
keyless system read the key in your pocket. That means that if you install this cheap aftermarket kick sensor will work
Just make sure that you not need to touch the metal handle and open when you push the button
Old 05-24-2022, 02:44 AM
  #46
Pwrks111's Avatar
2022 Mercedes C43 AMG coupe
did you attach the signal wire to the trunk release switch outside of the car (above the license plate) or to the trunk close button inside of the car on the trunk lid (see pic)? I cannot get mine to work, but it’s a c43 amg coupe. No trunk open button outside of vehicle
Old 05-24-2022, 03:30 AM
  #47
Gcl 220d 2018
yes you have to find the (open signal) and connect it to the module
Quick Reply: Retrofit kick tailgate opener
