Sponsored by: CARiD
Transmission
Old Nov 8, 2021 | 07:31 PM
dorenwickham's Avatar
2012 W212 E350 4MATIC
Transmission
On a few occasions when I started my car (2012 W212 E350 4matic), from parked position it would not select/engage any gear (D, R or N). I then have to turn off the engine, remove the key and restart before drive gear is selected.
Has anyone ever encounter such issue? If so could you please shed some light. I hoping this is not a huge transmission problem.
Kind regards
Dee'
Old Nov 8, 2021 | 07:41 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Check the auxiliary battery. It is responsible for powering the shifting of the vehicle into gear.
Old Nov 8, 2021 | 07:44 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Gear shift...
Chances are it's just your gear selector module (ISM) that is coming to be due for repair. An easy job given the replacement unit is available in stock.
Try to park on flat road and not hills to lessen efforts to shift out of Park.
ISM control unit
What's your current mileage??
Old Nov 8, 2021 | 07:45 PM
Raj1471's Avatar
Old Nov 8, 2021 | 08:11 PM
Current mileage is 62900.
Old Nov 8, 2021 | 10:39 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
#1 scan for codes... could be as simple as low battery voltage during a start causing messing with the CAN and messing with drive authorization between modules. Could be the ISM as well.... start with codes.
Old Nov 9, 2021 | 12:28 AM
davidjohnbamber's Avatar
2013 E550 Sedan
I had the same thing happening on my 2013 E550. With the car having been in service for over 7 years, and almost 8 years since the car was built. A new main battery solved all my issues. The first thing that got my attention after replacing the battery was seeing the back up camera displayed on the COMAND screen.
Old Nov 9, 2021 | 10:42 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
You had no backup camera??
Magnificent New Mercedes-Maybach S-Class Revealed: 12 Things to Know
Old Nov 9, 2021 | 01:44 PM
That makes sense. I am having intermittent lost of back-up camera as well.
Thanks for sharing.
Old Nov 9, 2021 | 01:51 PM
2013 E550 Sedan
I never really looked at the screen a lot when backing the car up. The old battery when first started must have had low voltage, that caused the back up camera, and not being able to shift out of park when first started. No problems for almost 18 months since I replaced the original main battery.
Old Nov 9, 2021 | 02:59 PM
63kMi... low voltage!
with such low mileage, your ISM is likely not seasoned yet.
Try floating your batteries more often
or get a new main if you think it's shot.
I try not to always tie everything back to my favorite interest of system disruption. Benz may have well reproduced with computers what British had perfected with legendary electricals!
Slideshow: Mercedes-Maybach has refreshed the S-Class with new lighting signatures, AI-driven software, and even more elaborate rear-seat luxury.
By Verdad Gallardo | 2026-03-25 18:01:51
