S212 Airmatic Calibration?
What comes to calibration, you don't need one unless you replace level sensor(s). The Airmatic spring system does not care what is lifting the car up. Level sensors tells it where it is and controls air in the springs accordingly..
This was spot on and didn't need to be calibrated. Turns out that one of the two ride height sensors had frozen -- perhaps getting jammed when they were yanking on the strut trying to remove the spring. This left the ride height on the driver's side just under two inches higher on the driver's side and about 3/4" higher on the passenger side. Surprising to me was that this didn't break the links. The shop was able to unfreeze the sensor without replacing it and it's back to normal ride height and ride quality now. It'll probably return to haunt me later and I'll end up replacing one or both sensors, but it's working again for now. Thanks for the help!
Normal coil spring also gets more load from more weight in the car and for this reason car goes down some. Beauty if the Airmatic system is that it adds air in springs to keep the car at set height but adding air does not increase pressure as the needed pressure is the result of the weight of the car.
As I explained in my post earlier the spring pressure would increase if the travel of the shocks would bottom out. In this case car would not be able to raise any further no matter how much pressure is present in the spring.
In short, as long as there is nothing mechanical holding the car down the amount of air pressure in each air spring results from the weight of the car. The springs are in place to carry the car, not forces against mechanical stops (shocks) that limit the upward movement of the car.
This is something you can easily test for yourself if you wish just using a balloon. It's not magic, it's physics. Believe what you wish, but I assure you that my vehicle is now at the correct height and the ride quality I expect out of it has returned to normal without increasing the weight of the vehicle (the external force). Likewise, the material of the envelope and its resistance to deformation hasn't changed, only the pressure inside of the balloon.
And I leave it in here...
First one is irrelevant since the car shouldn't be driven, the last one offers poor ride when returning from compression since it will hit the shock limits.
The second one, and only useful setting, defines the ride comfort since the pressure in the spring is nearly constant for any height between shocks limits. Any minor increase in pressure, dynamic, like the car coming down is controlled by the bag's elastic resistance itself (ignoring extra plenum/dampers)
My , perhaps incorrect, understanding
You are correct. The car floats on the air springs (like any car floats on the coil springs) without hitting the shock limits so the pressure in the air springs comes from the weight of the car. Of course, when the wheel hits a bump and wheel moves up very quickly the pressure in the spring goes up accordingly like when the wheel drops in a pothole pressure goes down for that time of the impact, but without counting for these the spring pressure is the result of the weight of the car regardless of the ride height.
1 - Air in and pressure value increasing and the car still down
2 - Air in and tire start expanding, pressure increasing and the car still down
3 - Air in, the tire continues expanding and the car suddenly start rising
4 - Air in, the car continues rising, and (here is the issue) the pressure remains the same
5 - Air in, car no longer rises, tire shape seems fixed ( still a bit of a bulge, more at the front than the rear for the same pressure), and the pressure starts increasing again until the valve is closed.
There are equivalent steps on the air spring. When the air spring reaches the maximum length of the shocks (tire at the maximum visible final shape), the pressure starts to increase to whatever you want (and the bags supports).
Equivalent exercise is before installing inflate two tires to a fixed pressure, install one in the rear and one in the front. Same pressure, correct? Same bulge when installed? Hope not, otherwise, your car would be missing the transmission+engine unit. Measure with an accurate manometer the tire pressures on both tires. Same as before installation? Nope. Same value for both front and rear? Nope. How much is the difference? Minor, but different. Splitting hairs? Possibly, but the conversation is already there.
The car floats on the springs and the force of the springs is just the counterforce to the weight of the car on the spring. As long as you don't fill the springs to reach the travel limit of the shocks the pressure in the spring stays at what the weight of the car gives it and nothing more-nothing less.
You are so lost with this it is unreal. Unbelievable indeed.
And for your info - there is no individual pressure sensors for each air spring. Only one in the reservoir.
