Sponsored by: CARiD
Mercedes E550 B28/7 pressure sensor downstream of throttle valve
Old Dec 11, 2021 | 12:06 PM
GregGuzik's Avatar
2012 E550 4MATIC | 2008 E350 4MATIC
Hello
Please help me to locate the sensor to fix the trouble code P010617
B28/7 "pressure sensor Downstream of the throttle valve
Part number if possible, and where this sensor is located.
Thank you
Old Dec 11, 2021 | 12:48 PM
Senecat's Avatar
1983 Nissan Shltbox
Wow, it's literally on page 1 of threads. Does anyone do any research themselves anymore? Seems like all most know how to do anymore is ask someone else how to do something.
https://mbworld.org/forums/e-class-w...e550-m278.html
Old Dec 11, 2021 | 11:59 PM
S-Prihadi's Avatar
Old Dec 12, 2021 | 04:35 PM
Senecat's Avatar
1983 Nissan Shltbox
Lol geez I tell ya!
Old Dec 13, 2021 | 05:12 PM
GregGuzik's Avatar
I did research, I found a similar topic but for AMG version. I was looking by trouble codes, not by MAP sensor issues and that was my mistake
Thank you!
Old Dec 13, 2021 | 06:09 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
The M157/M278 are the same platform, and share most common parts. So parts location will be the same, year per year (engine wise).
Old Dec 14, 2021 | 01:35 AM
GregGuzik's Avatar
For the reference
Old Dec 15, 2021 | 07:38 PM
GregGuzik's Avatar
Hello again
I replaced the sensor but still have trouble codes, please see the attached
Please help me out, thank you
Old Dec 16, 2021 | 08:33 AM
S. Madman's Avatar
Check the ECU pins for oil contamination. If oil is found, your harness may be compromised.
Old Dec 16, 2021 | 10:15 AM
GregGuzik's Avatar
Just checked, no oil was found.
Any other ideas?
Old Dec 16, 2021 | 12:52 PM
S-Prihadi's Avatar
Is the B28/7 you got as replacement a genuine one ?
1,111hpa of air pressure ( engine off ) means that is supposedly ambient pressure.
Normal condition , at sea level is 1,013 hPa or millibar or 101,325 Pa, same-same.
Your sensor is reading your engine being underground at -783 meters. Type in 111,100 Pa
https://www.mide.com/air-pressure-at...ude-calculator
Old Dec 16, 2021 | 12:58 PM
GregGuzik's Avatar
The car was idling during test, and yes I bought the OEM senor
Old Dec 16, 2021 | 02:19 PM
S-Prihadi's Avatar
The B28/7 should read vacuum at idle or 370 to 450 hPa there about.
Was the old assumed defective B28/7 sensor also reading the same wacky value at idle ?
Turn engine OFF, keep ignition ON so ECM is running.
Try to use vacuum pump to exercise the membrane of B28/7. Who knows it is stuck.
Unplug B28/7 from its position and let it read ambient atmospheric pressure. Read the pressure value, it should read ambient pressure like all other MAP/Pressure sensors B28/4 , B28/5 and B28/6 are reporting. +- 3 or 4 hPa is okey.
Use vacuum pump to create vacuum to B28/7 and see does it come close to the vacuum gauge reading ( yes, you must convert )
If still B28/7 alone is reading funny/error, simplest way is to use the other MAP/pressure sensors to take place of B28/7 to confirm IF wiring to B28/7 is the problem or the sensor itself.
The closest specification would be the B28/6, but if reading ambient atmospheric pressure only, all other 3 sensors would surely match.
No need engine running, just read ambient pressure with engine OFF and ignition ON.
Good luck
Old Dec 18, 2021 | 04:55 PM
GregGuzik's Avatar
Problem solved
Thank you for your help, the issue was caused by my racechip. After software update readings came back to normal.
Old Dec 19, 2021 | 01:00 AM
S-Prihadi's Avatar
Good to hear you found the problem.
However : Wow.... that is a scarry boost manipulation value.
Assuming 1,111 hPa at idle represents the boost manipulation gross value (at sea level), that is approx 600 hPa or 0.6 BAR or 9 psi of extra ACTUAL turbo boost under reporting.
M278 DELA46 standard boost is 0.9 Bar ( 13psi ).... holy cow, 66% manipulated extra turbo boost.
I am wondering, piggy back black box like RaceChip manipulation method, where and when the manipulated data is injected ?
At idle surely it won't manipulate anything significantly...yet, otherwise DTC code willl be generated by the engine ECM for whacky values....as you are experiencing.
RaceChip can't manipulate orginal fuel/boost/ignition/etc mapping of your ECM, it can only under-report value of the sensors to the ECM.
Something has to give.... I think the CAT system will suffer in the long term if the cheat is too crude.
I guess the plastic intake manifold and aftercooler can handle extra 9psi of pressure ?
Turbo wise, I don't know if extra 9psi will shorten its life by X% ?
M271.860 of 184HP uses 1.2 BAR boost or 17.4 psi.
Old Jun 11, 2025 | 01:48 AM
boostid's Avatar
12 S550
Bumping this old thread. What exactly did you update to fix this? The racechips or the Benz?
thanks.
Originally Posted by GregGuzik
Problem solved
