Sagging sunvisors - 2014 E300
Clear plastic retainers, yes...
Sister's W211 driver's side was sagging and someone glued velcro on the Alcantara headliner,
, it is $500 for each of the visors if you find them (last month there was one available in Germany). After a while it made a tiny hole in the headliner where the glue attached to. I opened the visor with a sharp spatula, and after breaking through the heat resistant glue I was able to see the source of the problem: a broken metal clip that presses on the shaft along the edge of the visor.Anyways, I just found a pair of 2009 AMG63 visors, not Alcantara, but they look brand new (impressively new) for $80 on Ebay. I could not resist, so got them. Screw the Alcantara suede feeling.
My solution of sliding the visor side-to-side on its pivot rod works fine for me, but obviously wouldn't help any if the visor couldn't be clipped into the ceiling receptacle. Good luck with that.
Maybe a couple of wraps around the rod with electrical tape or duct tape?
I concluded the special Benz lubricant had sublimated.
I then poped the trim pieces off my clunky sunroof for a repeat lub job on the spring drive but then my OCP started not posting temperature....
never heard of it.
