Sponsored by: CARiD
Is this timing chain rattle?
Old Feb 5, 2022 | 10:00 PM
Shuo Wang's Avatar
2014 E350
Recently I noticed this rattle noise coming from the engine bay. And the noise seems to go away or become unnoticeable once throttle is applied. Could this be timing chain rattle? I checked oil level and it’s full.
video link (sorry mbworld won’t allow me to upload one)
https://youtu.be/Tk0C5_jtUdo
File Type: mov
Old Feb 6, 2022 | 12:08 AM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
No that sounds like a bad pulley. Rattle typically only occurs on startup
Old Feb 6, 2022 | 08:24 AM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Unless you let it go long enough that the tensioner is toasted completely? My '12 rattles on start-up for 15-30 seconds, has 30k miles and original chain tensioner, seems to rattle less with 5W30 than 10W40, like 10 seconds or so.
I could be wrong, They did fix it on my '13 under extended warranty and it doesn't rattle on start-up
Old Feb 6, 2022 | 10:04 AM
Blkvip's Avatar
12' E559
try taking the belt off and see if any pulleys have excess movement. if you haven't done the pulleys and tensioner id do it. cheap and peace of mind.
Old Feb 7, 2022 | 03:53 PM
Shuo Wang's Avatar
2014 E350
I've never heard any rattle on cold start on this car. My audi s5 had cold start rattle and it was fixed by a newer timing chain tensioner, thankfully under warranty.
I'd probably get an auto stethoscope and tap it on different places to figure it out.
Old Feb 7, 2022 | 03:54 PM
Shuo Wang's Avatar
2014 E350
The pulley and tensioner were replacement 10K ago with OEM parts, so I doubt it's the issue. I could be wrong though. I'll give it a try this weekend.
Old Feb 7, 2022 | 04:06 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
we mean the timing chain tensioners…
Old Feb 17, 2022 | 05:08 PM
Shuo Wang's Avatar
2014 E350
Update, brought it to a mechanic. The rattling noise was caused by a failing belt tensioner. So it failed after only 10K miles. hmm.
Old Feb 17, 2022 | 08:42 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
unskilled labor or junk parts...
You had your belt tensioner and idlers replaced with OEM and less than 10kMi, it all failed again... that's when you invoke the free "repair warranty" -or find a new place with skilled techs & genuine parts.
I can't believe this failure being so short is anything remotely normal.
Old Feb 17, 2022 | 09:25 PM
Shuo Wang's Avatar
2014 E350
It got replaced 2 years ago and the shop only provided 1 year warranty, it really sucks. I am going to a new place for this repair...
Old Feb 18, 2022 | 01:14 AM
Senecat's Avatar
1983 Nissan Shltbox
Guide pulleys and tensioner are a 15 min job. Tensioner is a Gates unit you can get on ebay for $30. Don't bother paying OEM price.
Old Jun 25, 2022 | 07:54 AM
mercyfan's Avatar
Mercedes 2013 E350 4matic, 2013 ML350 RWD
What they replace to fix it Pierrejoliat?
Old Jun 25, 2022 | 08:07 AM
Timing chain guides and tensioner, I bought the extended warranty on that car, because I was still working and driving, so I put 20k a year for the first three years and then it was 3-4k a year until now, which is 85k miles currently. If I remember correctly it was at 49k miles. I'm pretty sure FCP Euro has the guide and tensioner as a kit sold together, I will need to do my '12 at some point, but I just turned 31k miles on that one, I still have the factory brake pads after ten years, 8 mm left!
