W212 Chirping Noise
I got a 2011 E350 last week. (Odometer: around 84,200 miles)
From this Sunday, the car has developed such symptoms.
1. The chipping noise came out when I turned the steering wheel to the right side. (Passenger side)
2. Occasionally, when I start the car, the chirping noise comes up (Passenger side)
3. While riding on the bumpy road, a chirping noise came up.
4. The chirping noise was gone when I stopped at the traffic light.
Why is this happening?
If this noise comes from the engine area, check the steering pump for low oil level, the serpentine belt and tensioner for integrity.
Don't ignore this too long if related to steering. I lost my steering assistance 30Yrs ago and still recall the experience very vividly ... inspect soon!
If it's just a mild case of noisy bearings, you may drive on it for a long while until repair.
While at the service desk, ask the dealer to check bearings freeplay on the opposite side and bent rims for wobbling, unless one was replaced recently.
Want to test it to make sure? Turn your HVAC system completely off. Any chirp?
How do you lubricate it?
1) remove two t25 screws and remove that plastic cover and dropped few drops of oil at marked location
I am not entirely sure if any oil got inside, I let it sit for minute or two and cleaned off what didn't get in.
2) Clean dust between motor and white fan and used wet bent q-tip to let some oil get inside motor(do this motor side down so that gravity will do the job) by lubricating small rod inside that holds fan and motor together. Do this few times all around rod to cover all angles.
I used my motor oil to lubricate it and I believe I did pretty bad job of lubricating it but somehow it still worked and saved me money from replacing the damn motor lol. I did this a week ago and that awful noise is gone so far.
I will tell the dealer center to look at the part you mentioned.
